Portable non-gas generator charging Prime
Discussion in 'Prime Main Forum (2017-2022)' started by pianohawk, Nov 13, 2017.
  1. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Volts = the strength of the electricity (analogy...the pressure in your tires; 36 psi is "stronger" than 10 psi)
    Amps = the rate of flow of the electrons (analogy...gallons per minute of water flowing out of a hose)
    Watts = measure of power. Volts x amps = watts (746 watts = 1 horsepower)
    watt-hours = quantity of electric power = watts x hours (analogy...gallons of gas in your tank)
    kilowatt-hours = 1000 times the line above
    Simply stated there is no easy, cheap, small, portable way to recharge the Prime battery. Just drive on battery power from home as far as it takes you, then run on the gasoline engine until you get back home. The gasoline engine is the most economical, cleanest burning engine Toyota can make (at this price point).
    MMBH and Lee Jay like this.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Well....
  3. MMBH
    MMBH Member
    155
    43
    But unfortunately the Prius Prime "Safety Features" that matter really only exist in the ADVANCE (imho) :(
  4. MMBH
    MMBH Member
    155
    43
    Just an outside the box thought.... Is there anyone in the neighborhood that would let you plug in at their place for the going rate?
    And apparently this is an oder thread so not sure if it matters at this point, but, love to know how it turned out and what you ended up doing! :)
  5. bwilson4web
    16,538
    Dang, I drive a Plus. Waiting to die . . . NOT!
  6. bisco
    52,863
    aren't we all?(n)
  7. MMBH
    MMBH Member
    155
    43
    Well, just saying that those minimal safety features in the lower Prime models are no big loss. Plus, it resulted in >$8,000 repair and loss of my vehicle for 3 weeks for an accident in my own driveway because I was backing up and clipped the flagpole in front which if those safety features were present should have warned me and sensed that a pedestrian or other object was in close proximity! Just not impressed with those minimal safety features int the Prime Premium! Sorry if you were offended by my response!
  8. bwilson4web
    16,538
    Not offended as much as thankful for TSSP. Regardless of what safety features, if we don’t look at the backup camera screen, might as well sit on the seat belt.
  9. MMBH
    MMBH Member
    155
    43
    FYI --- I was looking at the back up screen!!! I wasn't looking forward when it clipped the flagpole in the front because I was distracted by the friggin huge backup screen and the TSSP didn't go off to tell me that I was close to hitting it - so what good is the TSSP in the Prime!!!!
  10. MMBH
    MMBH Member
    155
    43
  11. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The solar roof is a joke. You get perhaps a mile worth of charge per day. Even a larger solar panel isn't much of a solution. A 4' by 8' produces around 200W for maybe 5 hours. Not enough!
    Generators are not recommended because their output is "dirty". i.e. it will eventually destroy your charger. Unless they are very large and connected to the grid. I have had to repair a lot of electronics powered by generators at forest fires.
    walterm likes this.
  12. dziadek1818
    dziadek1818 Junior Member
    28
    poland
    Hello,
    I wonder about this topic, since last reply few quite big solar generator have appeared in the market.
    Like this one for instance:
    AC 100V 240V High Storage Portable Solar Generator 3000Wh Power Supply for Camping, Backup Power DC/AC Output|Jump Starter| - AliExpress
    Have anyone tried to power their car via such solar generator?
  13. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    You could certainly use this to move electricity from some other source to your car, but unfortunately it would take much longer and use more total electricity than if you simply plug the car in directly.
    dziadek1818 likes this.
  14. dziadek1818
    28
    poland
    obviously, this is just follow up on this topic.
    This generator has 3kw capacity, prius battery has 8,8kwh . So it is like 1/3 needed.
    But I just wonder if anyone, just like author of this post has used such "non-gas" portable generator? :)
  15. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    You do understand that it's just words- there is no generator at all. It's just a rechargeable battery that you can charge up at home. You're still paying for the energy somehow.
  16. dziadek1818
    28
    poland
    no i dont understand that I need you to help :D :D
    and i reccomend you read the main post.
    Indeed, this is battery, portable battery can be charge via different sources of power and become a generator.
    I got pv at home almost off-grid so dont worry.
  17. Trollbait
    12,831
    With the ad blocker paused, I can't see what products the OP was considering, but it is possible to charge the car from another battery.
    The question is why would you want too?
    It would take three of those units to fully charge a Prius Prime. The, not included, solar panel they picture won't recharge the battery up in a day. That is a lot of money and hassle to charge a PHEV when away from the grid.
    If not having the engine come on is so important, then why buy a car with one?
  18. dziadek1818
    28
    poland
    as the main author put it, he needed that cos his company did not provide any charging station thus he came up with an idea (portable generator). At this time, market did not provide big ones. Now one can get portable 3KW battery.
    I simply followed that idea and ask if any one do this after last post. If anyone tried such idea :)
    charge at home, take with you in the trunk and use it later on, just as the main author needed to.
  19. Trollbait
    12,831
    He wanted to reduce his gasoline costs. One of those 3kW units power might provide enough charge for 10 miles of EV range; saving maybe $1, minus the electricity fees, per day. The power supply costs over $2000 though. There won't be money savings for 6 years.
    That's the issue with this, or adding more batteries to the car. It would have cost less to get a BEV or PHEV with longer EV range to begin with.
