Portable solar panels to charge your car?
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Aug 27, 2017.
  1. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    My husband drove the car home yesterday (400 miles), and I drove our half a million mile '07. He loves the car. (I'm hoping to drive it soon but I can't breathe inside it because of the strong chemical smell- asthma).
    He was wondering about plugging the car into portable solar panels at work.
    Has anyone ever done this? Is it possible? He has a 25 mile commute one way, I have a 62 mile commute one way. He would never need gas during the week.
  2. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Typical solar panels are set up for 12V DC output. You would need an inverter to convert that to at least 115VAC to charge a Prime. That's one problem.
    Then there's the power problem. An optimally set up solar panel (portable) would output about 40W. To noticeably charge the Prime you need about 800W, maybe more. At 115V and that 800W it takes 5-8 hrs to fully charge a depleted Prime.
    I don't think what you want to do is practical.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    The world’s smartest solar solution | smartflower
  4. David Beale
    5,963
    1,990
    Edmonton Alberta
    That is NOT a "portable" solar device!
  5. priuscatprimeguy
    2,730
    2,640
    looks "portable" :whistle: edit: It folds away in bad weather:D
  6. bisco
    52,878
    nope. you can't plug your car into anything, except a standard 120/240 outlet.
    #6 bisco, Aug 27, 2017
  7. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    "Someday, over the rainbow... solar panels fly... but why can't, they charge my Prius, why oh why, I cry?!" (Forgive me Judy!)
    Sorry Mr. PrimeCat, no battery storage yet, 1200 lb unit needs crane and special crew to install, and no cost figures offered. They're in Boston area, too far for me. Requires maintenance of system, lubrication, etc. by certified tech every 2 years. Sounds like theoretically cool concept, but to me sounds, "Too new to rate". Any system to charge my Prime would have to include some sort of power storage system which this system doesn't yet offer. Requires minimum 16ft of clearance. I'd want a system that doesn't mandate grid connection, so if grid power is lost due to earthquake, etc. I would still have solar power. Good luck with that one, currently!!
    #7 HPrimeAdvanced, Aug 27, 2017
    Jayne K and priuscatprimeguy like this.
  8. priuscatprimeguy
    2,730
    2,640
    The world’s smartest solar solution | smartflower can run three air conditioners at once.
    Energy output
    Nominal output
    2.50kWp*
    Annual output
    3,800-6,200kWh/a**
    Self consumption
    ~<100 kWh/year
  9. priuscatprimeguy
    2,730
    2,640
    A fully integrated, plug-and-play solar solution with a simple installation. smartflower is as easy to pack up as it is to set up, so you can take it anywhere.
    HPrimeAdvanced likes this.
  10. El Dobro
    El Dobro A Member
    7,106
    3,282
  11. priuscatprimeguy
    2,730
    2,640
    waiting for an answer back, will update when I know more:cool:
    HPrimeAdvanced and El Dobro like this.
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    If this is that important, then one should purchase a vehicle that meets those needs (volt, BEV, etc). Once one experiences driving on pure electricity, it's a powerful drug! ;)
  13. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Someone has done this by placing a flexible solar panels on the roof, combined with batteries and inverter in the car. He did not modify the car itself to protect the warranty but was a set up to plug the car while being parked from his set up. I just cannot remember which thread it was posted at...
    He had the parts he used posted.
  14. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    It was posted by Chris Jones at the thread "Estimated miles/best actual miles on EV charge." Very inspiring!
    priuscatprimeguy likes this.
  15. Trollbait
    12,832
    There was a Plus model that had batteries.
    Or wait for the solar roof option to arrive to the US.
  16. fuzzy1
    10,720
    It also weights ~1500 pounds, more than twice the rated load capacity of the Prime. So the Prime isn't taking it anywhere.
    And since I can't wrestle 1500 pounds in or out of my dad's F250 pickups, I'm also not taking it anywhere without a crew or lift.
    No price either. I bet that it will be cheaper to simply add more capacity to my home rooftop solar system.
    #16 fuzzy1, Aug 27, 2017
  17. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I would like to see a variation of the solar roof option for Prime, where you plug-in from external (home roof solar) instead of having the solar panel on the car roof.
    In any case, Prime is really designed as a solar vehicle, even though we do not get that option in USA. But we do get the chassis designed for that purpose, which is probably part of the reason the HV battery is stuck in the trunk and not hidden away more.
    I'd be curious to hear how the Prime and solar Prime sales are doing in Japan
  18. bisco
    52,878
    prime is doing so well, they cut u.s. shipments. no idea on solar roof.
  19. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    We need a Prime factory built here in Southern California now!! Everybody wins!!
    MMBH and bisco like this.
  20. bisco
    52,878
    i'm on board, maybe by the time it's up and operating, they'll have figured out how to tuck the battery beneath the deck.(y)
