Possibility using a gen2 Inverter assembly off the car?
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Dec 25, 2017.
  1. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    everyone! Happy holiday.
    Is it possible for the inverter assembly of a gen2 to be used off the car? This I mean, for instance, if I have an inverter that's being lying in the shop, could it be used for some kind of projects to either power some kind of electric motors, or not?
    Dxta
  2. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    Probably depends on the volts in and out that you need.
    You would need to link it to a loop of coolant so it doesn't overheat.
  3. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Thanks for the suggestion.
    I think I could also get that Inverter reservoir attached also, and the pump also been powered electrically from a 12volt battery or so, just to keep it cool.
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,952
    4,707
    Texas Hill Country
    Doubt it would work without an entire network of engine, battery, dash, and transmission computers along with their associated Inputs and outputs. Even then it would still have to be a vehicle operating within proper parameters.
    Dxta and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    It could be the 21st century version of the “hit and miss” engine of a century gone by;).
    Good luck with the project(y).
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    2 words......software programming.
    Dxta likes this.
  7. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    You're funny!:D
    Raytheeagle likes this.
  8. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    End of an ambitious project!?:oops::D
