Possible brake failure?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Jack1971, Dec 19, 2013.
  1. fuzzy1
    10,707
    The above highlighted words sound self-contradictory to me. Sliding normally means traction failure on a slippery surface, not brake engagement failure. Sliding generally indicates full brake engagement, but possibly with an ABS failure to prevent brake lock-up.
    Could you clarify?
    From piecing together past descriptions and federal passenger car braking regulations, I do wonder if actual standing on the brake pedal will override the power assist and electronic braking control layers, and put enough manual force into the hydraulic system to actually lock the brakes. This could be a result of federal requirements that a certain amount of unassisted manual braking still be available to override a failure of the power assist system, if the pedal is pressed hard enough.
    What is the condition of your tires, e.g. type and remaining tread depth? What were the road surface conditions, e.g. dry or wet or icy? Rough asphalt or polished concrete or metal plates or grate?
    #21 fuzzy1, Jan 20, 2021
  2. Tiamaybe
    Tiamaybe Junior Member
    2014 Prius c
