Possible dead beattery?
Discussion in 'Generation 1 Prius Discussion' started by renzo813, Nov 24, 2018.
  1. renzo813
    renzo813 New Member
    nyc
    2002 Prius
    I have a 2002 prius and when i turn my ignition lock cylinder to the on position. The display screen starts to twitch and everything starts to die. But then when i turn the engine on everything is fine. Any help? The 12v aux battery isnt even a year old.
    52,887
    hard to say without testing. do you have a volt meter?
  3. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    I'd 2nd that you need to check the voltage of the 12v auxiliary battery before and after start. Sounds like the alternator is boosting the voltage up to make your ancillaries work okay. So your year old battery either needs a good charge or its shot.
  4. renzo813
    renzo813 New Member
    nyc
    2002 Prius
    I got it checked out at autozone they said that the battery is good and it could be an electrical problem. I'll add that i cleaned snow off my car and threw the brush in the trunk and some snow got. On the battery and the terminals. Since my cousin didnt cover the battery after he jumped his car. Could that have been what caused this?
  5. bisco
    52,887
    na.
    could be your cousin jumping it improperly though
  6. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    what do you mean by "everything starts to die"? My main screen on my 2003 does not like the cold and will stay blank until it warms up. Sometimes I have to restart the car to get it to display a picture even after its warmed up. And many times it will "twitch" until it is warmed up.
  7. renzo813
    renzo813 New Member
    nyc
    2002 Prius
    The screen starts to twitch and all the lights just dim out until theyre off. Then i cant start the car.
  8. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Hmm, im at a lose for that one. How did autozone check the battery? It has to be put under some kind of load. Try connecting another battery to your prius with jumper cables and see if it still does it. If it does than its not the battery.
  9. dabard051
    dabard051 Tinkerer-in-Charge
    262
    98
    Rochester, NY USA
    2002 Prius
    Perhaps not the battery, but the battery connections. Inspect them for corrosion, and make sure they are tight and well-connected to the battery posts. Voltage measurements are VERY helpful analysis tools here. From your symptoms, it sounds like you have a poor connection between a healthy battery and the car electrical system. There is an old-fashioned battery terminal cleaner tool (cylindrical steel bristle brush) available at most car parts stores... this is a classic problem which shows up at the onset of cold weather/winter in many parts of the country. Good luck!
  10. renzo813
    renzo813 New Member
    nyc
    2002 Prius
    Ok thanks a lot ill give these a try and get back to you. And yea it started happening during a snow storm (go figure)
