Possible improvement to the car for cooler areas?
Discussion in 'Gen 2 Prius Technical Discussion' started by David Beale, Dec 27, 2007.
  1. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    Pardon my naivete, but what does -30C/-22F feel like? What are the hallmarks of this temperature? Does coffee freeze before it hits the ground when spilled? Does saliva freeze? Immediately? Etc?
    Here in sunny Northern California we've already had our annual two days of actual "weather" and it's only 5-Jan! Yesterday and the day before it was rainy and windy like it would be in an east-coast style rainstorm, complete with thunder and lightning and all our crap blowing out of the back yard into the street and neighbors' yards, including ATTACK OF THE KILLER UMBRELLA. It was amazingly wet. The rain wasn't that drizzly stuff we locals call "rain" but actual rain where you have to use the two fastest settings on the wipers and everything.
    I got to enjoy my 205 tires and my BT Tech stiffening plate. WOO!!!
    The BT Tech stiffening plate is nice in most wind gusts but you will still get the occasional symmetric wind gust (plate does nothing to help against symmetric forces) and it scares the heck out of you.
    ~ dan ~
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    easy to "kinda" know what its like...
    have any warehouse stores?
    ones around here require you to go into freezers set at -10 F... that is close...
    be warned... do not breathe in deeply at first...air that cold and dry can really cause some damage to your lungs
  3. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Actually lung damage from breathing deeply in -20 to -50C weather is pretty much a myth. Do it all the time, cross country skiing, snow shoeing, and running, for example.
    You can feel ice crystals form in your nose (tingles a bit - doesn't cause any problems). Liquids do not freeze before they hit the ground. Not even at -50C. Whether hot or cold.
    Down to about -40C there are no really noticeable things happening, except below about -20C snow "squeaks" when you walk on it. You hear cars coming because of the squeaking of the tires on the snow. You get better traction, as ice becomes less slippery.
    Below -40C (that's also below -40F) it gets really quiet. I'm not sure if that's because nobodies car will start ;) , or because of the dense air. You hear the houses and the ground crack loudly from time to time, due mostly to shrinkage.
    Cars ride really "rough" below about -20C (that's just below 0F), due to the tires being really stiff and the shocks also stiffening up. You -can- break things if you push it too hard.
    The air is also very dry.
    When I get into a car and sit down when it's below -30C, it's -on- the seat, you don't sink into the seat. A little voice inside my head says "oh oh!" when that happens, as I wonder if the car will start. You all hear that voice, right? :)
  4. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    try it when going from 70 to -20 in a few second
  5. fruzzetti
    377
    I don't know what you think of the transition from cool to hot, though :p
    I flew into MCO (Orlando) one cold, cold morning in July 1999. I must have ignored the pilot's description of local conditions. I was on a redeye that left a frigid SFO (San Francisco) at 22:00 the previous night. MCO is a large airport with monorail-like hanging trams to carry you from the terminals to the entrance. The whole process looks very outdoorsy because of huge windows; it is in fact totally sealed. I walked out the front door of a nice, cool airport into a local 08:00 at 86F. The large wooden benches outside the airport were sweating.
    OMG.
    ~ dan ~
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Well, as David mentioned, ice and snow become "squeaky" when you walk on it. Ice near the melting point is far more slippery than ice at -40.
    The only way I've had coffee freeze in the air, was at -40. I flung the cup upwards as hard as I could, creating a fine shower of coffee. It turned to ice crystals. Otherwise, if you pour it on the ground at -40, it will take awhile to freeze
    One thing you do *not* do is try to lick anything metal at that temp. Yes, as a kid I found out, like a lot of kids up here do. I do believe Mythbusters had a nice episode on cold weather, at least what passes for cold weather in the Sierra Nevadas.
    The cold can really effect a motor vehicle. Conventional 5W-30 oils turn solid below -30 C, and regular 80W-90 gear oil turns solid at -25 C. In severe cold, say down to -50 C or colder, a battery stops working. It's too cold for the chemical reactions.
    But the only way to really understand cold weather is to experience it. We're currently having a heatwave with highs of +33 F, but check back when the lows are near -40
    If I had a choice of a damp, nasty climate where you have to dash from A/C car to A/C house, or -40, I'd take the -40. Mold doesn't grow very well at -40
  7. Orf
    Orf New Member
    414
    Devonport, Tasmania
    The coldest I have been was in 1960 when I was plunged into an environment where the temperature was -84c. Boy, was it cold, especially as I had summer weight clothing on and part of that was torn. Luckily I was only in that environment for a few minutes.
  8. Ozzyprv
    Ozzyprv New Member
    39
    Red Deer, AB - Canada
    Besides for David and jayman comments (excellent winter-like summary) the only thing I can add is that it takes like 6 months to get used to it.
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Nah, more like a week or two. The biggest plus in my book: no bugs.
  10. Ozzyprv
    Ozzyprv New Member
    39
    Haha, no way!. No if you are coming from a Tropical country (Venezuela for example).
    I came to Canada 5 years ago, I remember wearing long underwear that September '02 because it was "too cold" (~10C). Now, I wear short whenenver it is above 5C.
  11. icarus
    icarus Senior Member
    4,884
    976
    earth
    What -40 does is make you realize how warm it is at 0C. (freezing) We light the fire in the cabin @ -35c and within an hour we're sweating. Look down at the thermometer and it says -5c. It becomes all relative. I'll take --30c over plus 30c any day!
    Icarus
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    Oh, that's entirely different.
    Personally I can't stand humidity. I can deal with Palm Springs/Death Valley, California *much* better than say Miami, Florida
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Me too. No bugs at -30 C
  14. Ozzyprv
    Ozzyprv New Member
    39
    After spending 20+ years at ~+30C me too.
    This morning -20C, tonight's low -22C, just getting there....
  15. David Beale
    5,963
    1,988
    Edmonton Alberta
    Well we've drifted into another topic entirely, but here goes anyway.
    You will get used to the cold. I think the body adapts. What you DON'T want to do is freeze or come very close to freezing any extremities. Once you do that, they will freeze more easily the next time. So overdress, and remove a layer if you feel you're close to sweating.
    I find if my feet are warm, I'm usually just fine. :)
    Down filled booties are great!
    But it's not cold here yet, just cool (-20C or so). I hate the warmer weather like we've been getting the last 10-15 years. It's messy. I long for the extended weeks below -20C because the roads are nice and "clean", icy from exhaust condensation, but clean!
  16. fruzzetti
    377
    I love these forums... :D
    I actually enjoy cooler weather, except when I first wake up; that's when it should be warm and nice and we should all stay in bed and not go to work (kids were awful today :p)
    ~ dan ~
