Possible Monthly install meets. Bay Area-Fremont
Discussion in 'Local Prius Club Main Forum' started by Priusmpg, Jul 1, 2014.
  1. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    There must be a closer option for you, but the best that I know of is in the Concord/Walnut Creek area.
    His work schedule is generally full for weeks/months out, and you might get lucky and be offered a time slot.
    #1141 SFO, Jul 29, 2020
    Raytheeagle likes this.
  2. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    My blackstone oil analysis results are below, if text in "comments" section are too small to read let me know. Thanks again guys for helping with the maintenance during the meet ups & the almighty OCC install.
    Had to do an oil change at 11,000 miles due to life circumstances, usually it's changed in 13,000 mile intervals. Not a trace of coolant or water in the sample so the OCC is definitely paying off.
    acceleraptor, SFO and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    Looking good:).
    You going to sample again and monitor:whistle:?
    Or just let it ride;).
    Maybe one of these days we'll get to meet up(y).
    SFO and Grit like this.
  4. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    I plan to send a follow up sample with 13,000 miles because the tested sample was from January to June so I'd like to see a summer (June to December) sample test result. The test result was to determine if the transition to Penzoil Platinum Ultra Plat w/5K OCI was an order, since sample didn't come back w/high metal wear I will stick to Redline & 13,000 mi OCI for now.
    Meet ups will happen again, some of us are due for maintenance, BBQ and fancy assortment of beers.
  5. Raytheeagle
    11,265
    15,518
    2019 Prius Prime
    By the time the next one is, the hole in the ground in my backyard should have water in it:).
    It just took the pandemic to convince the wife it was a good idea:love:.
    We'll have a way to cool off if I host (y).
    SFO likes this.
  6. Ianmeister
    Ianmeister Active Member
    316
    318
    Meridian Idaho
    Hey all. This is a good a place as any. So next month I’m moving the family out of California to Meridian Idaho. Thanks for all the fun but it looks like another meet here in the SF Bay Area is off the table.
  7. Raytheeagle
    11,265
    15,518
    2019 Prius Prime
    Good luck in Idaho :).
    Was nice of you to host the one meet up at your place(y).
    acceleraptor, Triparadox and SFO like this.
  8. Triparadox
    Triparadox Active Member
    201
    108
    Take care. Thanks for the meetup. It was helpful for me. Managed to bring my car back and the problem was that they needed to add more sealant (or something along the line).
    I'm looking forward to the next meetup since I still need the EGR cooler cleaned. I can't host due to my circumstances, but I should be able to bring some meat and help other members with simple tasks like changing oil, tranny fluid, and tire pressure/rotate.
  9. Raytheeagle
    11,265
    15,518
    2019 Prius Prime
    When we get out of COVID (or at least with less local cases), I can foresee a meet up again:).
    Might have to put some new protocols in place, but that's doable;).
    No need to share certain things:cool:.
    But if at my place, the pool should be done by then(y).
  10. DJexcess
    DJexcess Junior Member
    Hi everyone,
    Just moved to the Sacramento area last week from socal. Looking to purchase the gen 2 club in the near future. Still looking shopping around in my budget. Just jumping on here for research purposes. anyways...I do graphic design/photo/video. Would you all be interested in getting some merch done for the next meetup? Shirts, caps, stickers, pins, maybe? I'd love to do a highlight montage as well. I love the prius community you guys have been cultivating.
    Montgomery and Raytheeagle like this.
  11. mohater
    mohater Junior Member
    52
    Fremont CA
    Anyone close to the tri valley (Dublin, San Ramon, Pleasonton) area with a laptop/vci/techstream and interested in helping me diagnose a red triangle with no codes detected by the shop? I'm in San Ramon, vehicle is a 2005 prius (donated car through a non profit, I'm getting the car ready to hand off to a client of the non profit.
    Happy to buy someone a delish meal for the help. Thread in question:
    Red triangle, no codes | PriusChat
    Thanks,
  12. Raytheeagle
    11,265
    15,518
    2019 Prius Prime
    @Joele3 has a smog shop off of Crow Canyon Road:).
    He might have a setup:whistle:.
    Good luck with your project(y).
    mohater likes this.
  13. mohater
    52
    Fremont CA
    Thanks for that. I'll DM him.
  14. vipjun
    vipjun Junior Member
    Hello, looks like there are no meets going on in Fremont because of the pandemic.
    Anyone have a good referral to a local mechanic or is Berkley the best bet? I'm at 101,000 miles and I think a major service is due.
    Would appreciate any advice.
    Gen 3 2010
    Must change from the manual.
    Oil
    Engine Coolant change
    Should I also do the following?
    Inverter Coolant change
    Transaxel fluid change (have no idea when this was ever changed)
    Brake fluid change (I've had the car 4 years now, brakes fine but also read about bleeding might mess up ABS)
    (Brake pads were changed)
    From the forum it seems these are due or close:
    Spark plugs
    Clean hybrid system (Not really sure what this entails)...
    Called 2 dealerships and was quoted pretty high compared to searches..
    I also am a bit unsure as one place quoted me $250 for engine and inverter while another gave 2 sep quotes of $250 + 250...
    Oil change : $140
    Engine coolant : $250
    Inverter : $250
    Transaxel : $260
    Brake fluid : $170
    It looks like $1,000 to turn a few bolts and bleed out the system then refill the liquid lol.. I know i'm oversimplifying it but it seems a bit ludacris.
    TBH im not even confident that the price will be the same once i get to the dealer by the way they quote things ... I've seen them do this tactic of making you wait basically killing your day and then quote you some higher than discovered price... You want your car back and lost a couple of hrs already and are at their mercy.
    I looked at some of the DIY videos, it doesn't seem that hard but I don't have a lift or tools.. I heard there are some places where you can rent just a lift and DIY anyone know what this is?
  15. PriusFruit
    PriusFruit Member
    97
    102
    San Francisco
    I've used this place since I bought my Prius back in 2017 anytime I couldn't do a maintenance on my own. I'm happy with them. They focus only on Toyota and Lexus. His name is Anthony, if you end up calling them.
    (I can't seem to add a link right now)
    The shop is TLS Auto Service in San Jose.
    acceleraptor, SFO, Xterra72 and 2 others like this.
  16. PriusCamper
    PriusCamper Senior Member
    12,512
    5,070
    Pacific Northwest, USA
    Yikes!!! Life in the SF Bay Area is expensive... I usually do all those things (other than brake fluid) for 1/3 that price...
  17. ericbecky
    ericbecky Hybrid Battery Hero
    4,382
    3,243
    Madison, Wisconsin
    You have many knowledgeable and trustworthy choices in the Bay area.
    East Bay
    Arts Automotive
    Argonaut Garage
    SF
    Luscious Garage
    Pat's Garage
  18. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    Luscious Garage in San Francisco is amazing and their reputation is beyond compare. Absolutely fantastic.
    But you can also do all of these things yourself, and you can find very clear videos explaining each one here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    All those prices are extremely too high. Oil change is about $50 with good oil. But if you can do your own oil change, the engine coolant is very easy and the inverter coolant not much harder at all. Trans fluid is a pain -- it can be messy. I think Luscious does it for $100. Brake fluid is easy esp if you have two bottles to catch the fluid, like these excellent ones:
    Schwaben - 007481SCH01A - Brake Bleeder Catch Bottle
    If you have a garage you can work in, get a floor jack from Harbor Freight; they are excellent. And you'll need two jack stands and that's all done.
    You can do all this stuff yourself. You can Facetime me if you have questions while you're doing it. One at a time, and you'll build up confidence.
    acceleraptor, vipjun, Fostel and 3 others like this.
  19. Justify1
    Justify1 Junior Member
    Fresno
    Need help I’m 70 love my car but have to replace my hybrid battery,won’t pass smog till I fix it,live in Fresno.Do you know where I could take my car.
  20. Sharkey
    Sharkey New Member
    Northern California
    I'd be down to attend this a couple times a year, if there's one closer to Sac that's even better for me. I have a lot of tools and a proclivity for studying online repair tutorials.
    Triparadox, w84me, DJexcess and 3 others like this.
