Possible new, old 2001 Prius, owner?
Discussion in 'Generation 1 Prius Discussion' started by goldenchild, May 21, 2010.
  1. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
  2. goldenchild
    goldenchild New Member
    Bay Area, CA
    2003 Prius
    I
    :eek: I actually didn't notice. I think I got lucky just to catch up to it at the light.
    I turned off while it was continuing straight, but I did notice excessive tapping of the breaks when there was no need for it (i.e. no close cars in front)... hmmm?
    But would they really allow that robot manned vehicle to roam free like that? I doubt it.
  3. jk450
    jk450 New Member
    55
    The "leak detected" definition does not refer to electrolyte.
    The P3009 code does not necessarily indicate a battery problem.
    Not always.
    Is someone panicking?
    Good to hear. What is your understanding of P3009?
  4. bwilson4web
    16,547
    It is a poor question that ignores the original poster in a forum:
    We are here to address the original poster's questions comments and observations. Once again you failed to contribute anything to this thread.
    If you have some facts and data, post them . . . with the backup data. Show by example that you are not a hypocrite by taking a big dose of your own advice and offering the answer to your own question.
  5. Patrick Wong
    18,210
    6,526
    DTC P3009 means that there is a high voltage leak to ground, which is a potential safety issue. Normally the high voltage system is isolated from ground. The hybrid system can detect a ground fault.
    The problem might be caused by electrolyte leaking from a battery module. However it could also be caused by any of the components that contact the high voltage, including the traction battery, the battery ECU, the battery cable leading to the inverter, the inverter, or the transaxle.
    You said that you assume everything is OK now. Does that mean warning lights are no longer present?
    It's very good that you are going to have the car inspected. Which dealer are you taking the car to? (I lived in Silicon Valley for 24 years.) Good luck with that process.
  6. goldenchild
    Bay Area, CA
    2003 Prius
    I
    Well, I've only had the car for about 4 days now and everything seems to be okay (i.e. driving is okay and there are no warning lights present). The independent dealer I purchased the car from said he'd been driving it since he obtained it in December 2009 and he has had no issues with it. Not sure if he was the one that brought it in (possibly?)... I should give him a call and find out.
    What concerns me a little bit is that there doesn't seem to be any closure on the dealer comments (I copied and pasted everything that was listed for that particular visit).
    I am planning to take it into one of the dealerships on the Peninsula. The person I know has been servicing my family's toyotas for the last several years and I trust him.
    Thanks for the good luck wishes!
    And what is going on up there ^ (2-3 posts up)? I sense a little hostility among posters (not that it's very uncommon in many forums)? :eek:hwell:
  7. bwilson4web
    16,547
    Thanks Patrick,
    I'm thinking module electrolyte leakage is the likely cause:
    • Appears to have cleared - he is not getting the original codes and the 'dealer' didn't report a problem. This suggests it is an intermittent with one occurrence.
    • Climate, humidity and salt - I'm pretty sure they have a lot of fog and areas with airborne salt. It doesn't take much to make a fairly high resistance trace that could trigger the fault. His area has that type of climate.
    • History of electrolyte leakage and P3009 - we've seen it more than once and there was a recent posting by someone who pulled the battery, cleaned up the area, and has yet to see the problem come back.
    When he gets a chance to have the car surveyed, it should include reading out the 19 module-pair voltages to see how balanced they are (anything under 0.3 is good news.) With the Auto Enginuity, someone could read out the module-pair internal resistance, another good metric.
    So all in all, it sounds like an 'one time' and though it bears watching, I wouldn't be too worried. If it comes back (or when) there will still be time to deal with it. Of course in our case, it would be a 'convenient excuse.' . . . "Sorry Honey, I have to check out the P3009 and can't run to the store right away."
    I don't remember if we discussed traction battery characteristics, driving to keep it happy:
    1. HEAT is the enemy - everything that follows is to help minimize heating the traction battery.
    2. Park in the shade instead of sun - a Southern thang, it also tends to keep the cabin cooler too. Just aware that some tree sap can be difficult . . . or wash the car more frequently.
    3. Avoid excessive regeneration - so descending hills, try to use "B", especially the larger, +500 ft, and steeper ones, +8% grade. This tends to reduce the traction battery overcharge that happens descending tall hills at high speed.
    4. Avoid excessive regeneration - when you can, coast to a stop versus running up to the exit or intersection and hitting the brakes. Be considerate of other traffic but often coasting down to a stop is a better way. I often just shift into "N" although there are laws against being in "N" going down a grade (plus the speed build-up is rapid and can make the ride somewhat scary.)
    Over time, you'll discover there are many 'slower' vehicles on the road and they make excellent 'pace cars.' So a nice moving van is perfect and I'll follow them with plenty of space for relaxed, care-free driving. The overtaking traffic will see the truck and curse the truck as they 'successfully' pass you and the truck . . . The gas pump hates that kind of efficient driving. <GRINS>
  8. goldenchild
    Bay Area, CA
    2003 Prius
    I
    One step ahead of you on the heat issue :). The Prius will get the garage over my beloved 08 Odyssey Touring van when the summer heat arrives. Both my wife and I's work are garaged parking structures, so we should be good there.
    Right now, I find myself constantly looking at the "Power Cycle" screen. The one that tells me whether I'm on electric, gas, or both... and whether or not the electric battery is being charged or not.
    Is there a general rule of thumb on what the optimal speeds are for flat side streets and freeways?
    My commute to work is a little under 3 miles and is all side streets. I find myself babying the gas pedal when the light turns green (i.e. pressing the gas pedal very lightly as I slowly get up to the speed limit).
    My wife, on the other hand, I'm pretty sure just drives it like a normal car (non-hybrid). But I'm certain she will follow the advice I pass on to her.
  9. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    You will get pretty lousy mileage due to your short commute. As for babying the gas pedal, if you're doing that so that you accelerate while keeping so lightly that you're preventing the ICE from coming on, don't do that, if you want better mileage.
    As I posted at http://priuschat.com/forums/gen-ii-...slightly-dissatisfied-my-mpg.html#post1126079 which came from a PDF at http://priuschat.com/forums/gen-ii-...angauge-best-threads-mileage-improvement.html
  10. jk450
    jk450 New Member
    55
    As far as I can see, no one is ignoring the original poster.
    That is a tacit understanding.
    With all due respect, I strongly disagree. The original poster deserves accurate information. At present, there is no information to indicate whether or not the OP's P3009 has been caused by a battery issue. Moreover, your post indicated to me a lack of understanding of the code on which you were commenting. I posed my questions so that you would have an opportunity to clarify yourself. That's only fair.
    In this case, there is no need for that. The errors on which you have based your assumptions are basic enough that they can be explained without data. For example, the description of P3009 that Patrick Wong offered can be readily found in the Prius repair manual. You have said that you own a copy of that manual. Why not read it prior to posting? It would take no more than a few minutes.
    Given that you had posted the claims that I had called into question, and in some cases corrected, it was only fair that I give you the opportunity to explain those claims. However, I see from your follow-up post that - in light of the subsequent corrections that forum members have made to your post - you are now backing away from your original diagnosis and characterizing it as more of an educated guess. That is a bit of an improvement.
    A gentle observation: Not everyone can be right all of the time. This forum is for learning. Indeed, if someone were to correct a post of mine, I would be both thrilled and thankful. I have no desire to spread misinformation, and I make an honest effort not to do so.
    However, while I have hope that you mean well most of the time, it is - to put it kindly - fair to say that you have a wee history of misbehaving when it has been pointed out that you have posted incorrect information. It does not serve the forum well to drag out words such as "fool", "lazy", "sociopath", or (in this last post) "hypocrite" in response to folks who have taken the time to correct your posts in an effort to ensure that those who ask for help do not get off track. No one else on this forum uses such language. There is simply no need to do so.
    In addition, I cannot help but notice that despite your rage at such folks, you do not counter their corrections. If you think that such corrections are themselves in error, please feel free to explain why you think so. Otherwise, it is a simple task to admit the error and move on. Not a big deal.
  11. jk450
    jk450 New Member
    55
    While an apparently intermittent P3009 will usually return after a short time, there are exceptions. Perhaps your vehicle is one of them. Just drive it and see what happens. Most of the time, P3009 will set without adversely affecting vehicle operation.
    It may be a cause of poor documentation on the part of the service writer. It may also be that the technician could not find a problem, despite the code being set. Intermittent P3009 codes can be challenging to diagnose.
    Some folks get upset when their technical advice is corrected. Egos can be fragile.
  12. goldenchild
    Bay Area, CA
    2003 Prius
    I
    True... There is not much I can do outside of the inspection (which is now looking more like an appointment next week now :mad:). I do plan to bring this notation up with the mechanic, but who knows if they will find anything. Just gotta keep on driving it until it comes up again.
  13. jk450
    jk450 New Member
    55
    Five months is a long time for a P3009 code to stay away. Perhaps that is a good sign. Are you able to determine from your records the rough number of miles the vehicle has been driven since it set that code?
  14. goldenchild
    Bay Area, CA
    2003 Prius
    I
    I can actually tell you exactly!
    On 12/29/2009 when the dealer investigated the problem, the mileage was at 111,344. As of yesterday at around 6pm, the mileage was at 113,507 ;)
    ETA: Now, I can't say whether the warning lights have come back on since the end of December. I can only speak on the last 4 days that I've been the owner of the car.
  15. bwilson4web
    16,547
    You just did with this selfish post. Stay on topic and address the original poster and these threads will combine into an excellent work worth sharing.
    BTW, there are more resources available on the net. I can recommend:
    • Ecomodder.com - a great place for folks who modify any vehicle for improved mileage. Some of their work is truly awesome. I can personally recommend Orange4Boy whose saga has been well documented here including swapping the transmission and some impressive mods. As much as heat is the enemy of the traction battery, it is the friend of the efficient driver and he has nearly 2 kW of block and transmission heating to improve mileage.
    • Yahoo Groups "toyota-prius" "Prius-Europe" and "Prius_Technical_Stuff". There is also a group that deals with the NHW10, the very first Prius sold originally in Japan but now finding its way to other markets.
    • Also, if you want a good car mag, I'd recommend: Autospeed.com - it is a free Internet magazine written by an engineer. Julian was the first to put a turbocharger in an NHW10 Prius: The Story of Turbo'ing a Hybrid Prius, Part 1
    Warning: good Prius resources can lead to 'loss of sleep' and family complaints . . . but it is terribly interesting!
  16. jk450
    jk450 New Member
    55
    P3009 can be accompanied by other issues as the root cause of the problem progresses. So it's encouraging to note that more than 2000 miles after the code set, your vehicle is still running well.
    If the problem returns, there are folks on this forum who are familiar with that code. Time will tell.
  17. jk450
    jk450 New Member
    55
    I'm going to pass on the lecture. Thanks for the offer.
  18. goldenchild
    Bay Area, CA
    2003 Prius
    I
    I decided to go with Fuelly... it just seemed like the less "busy" of the 4 sites.
    Still haven't been able to make it to the dealership for that inspection (have been super busy with work and family activities), but the car has been awsome these last few weeks!
    I estimate that I am getting about 45 mpg between my 5-day 3 mile (one-way) side street commute and my wife's 3-4 day 10-12 mile (one-way) freeway commute.
