Possible problem ahead?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Janis, Mar 19, 2014.
  1. Janis
    Janis Junior Member
    I filled my 05's gas tank but didn't really look at the gauge. When I got home, I was taken a bit aback as I had only driven 48 miles and it said my tank was only half full. The next morning I attempted to add gas but the fuel pump kept clicking off. I drove another almost 100 miles without the gas gauge moving but the check engine light came on. I asked a local mechanic to reset the check engine light and ask his input. He told me to add just a couple of gallons of full octane and see what happens. When I did (2.2gal) it clicked off and the gauge went to full. The problem seems solved but I am wondering if I have a gas gauge that is going to need repair.
  2. JC91006
    16,939
    8,647
    You can try disconnecting the battery and letting the computers reset. That will force the computer to re-read your fuel level. There are many people, including myself, that has issues with the reading of the gas gauge in these cars. Sometimes I can put in 4 gallons and my car would fill up to full from only have 3 pips remaining.
    52,927
    how long have you owned it?
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Prius is designed to use regular gas, so this suggestion seems odd. Maybe he had his reasons, but the full octane gas is not the key here. Rather, it is the Prius GenII gas tank bladder that is reluctant to expand fully in cold weather which causes many people trouble. Many threads here about the "Guess Gauge".
    tanglefoot likes this.
  5. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I've heard of high-octane gas causing the check engine light to come on in Prii. I don't know how the higher octane itself would have helped anything either. It was probably just a matter of allowing the fuel bladder to expand before adding more fuel.
    Try only pumping gas at the slowest possible speed (first click on the pump handle). This helps the fuel bladder conform to the increasing fuel volume instead of shooting air up the fill tube right away, which causes the pump to click off.
    What was the outside temperature? The fuel bladder is definitely less temperamental when it's warm.
    I've heard of clogged evaporative components causing similar behavior. Maybe someone will chime in on that. A leaking fuel cap is also a common cause of the check-engine light.
    The fuel gauges on these cars may have the most...personality of those in modern autos. They have some strange behavior. Sometimes, adding a few gallons doesn't cause the gauge to rise at all. Upon drawing fuel, the gauge readings are not linear (often, the first pip will last 80-100 miles, and the following ones drop off much faster).
