Possible retrofits to '04 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by jridden, Oct 27, 2006.
  1. jridden
    jridden New Member
    I just purchased myself an ex-fleet 04prius and was dissapointed to see a couple of features lacking.
    - First was the smartkey. Mine has no transponder. I have to insert this into the console to start.
    - Second was navigation
    Is it possible to retrofit either of these two items into a Prius?
  2. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Short answer: No it is not economically viable.
    Long answer: Sure it is possible you could buy all the parts and have them installed, but it would be cheaper just to buy a Prius with all the stuff in it.
    You can always buy an after market Nav and have half your problem solved, but I'm sure you know that.
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    after market nav options can be had.
  4. Tideland Prius
    16,445
    There are aftermarket options to install a smart-entry feature. I've seen someone with an 01-03 Prius have that smart-entry feature. You just need a car and a reader installed in the doors. Do a search on smart entry. I'm sure you can find what you need.
  5. benlenz
    benlenz Junior Member
    31
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 27 2006, 02:37 PM) [snapback]339638[/snapback]</div>
    I want a Smart Entry System on my HOUSE. Where can I buy that?
    Seriously. :mellow:
  6. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(garbageman @ Oct 27 2006, 05:08 PM) [snapback]339716[/snapback]</div>
    I've seen doors with a fingerprint scanner, combination and there used to be one that operated with the Homelink, but none like the SKS. :(
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    makes me wonder why garage door openers cannot recognize the car when it pulls up without having to hit a button first
  8. Tideland Prius
    16,445
    Ok, I did some searching for 10 mins and I can't even find that page I found last year with the home smart key system :blink:
  9. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
  10. daniel
    14,487
    1,519
    Spokane, WA
    I suspect that it's not practical to retrofit an SKS system into a base-model Prius. However, I am very happy with my Garmin StreetPilot 2720 GPS. It has the advantage of sitting where I can see it more easily than the car's screen, and the advantage that I can be using the car's screen for its own displays, or for the CAN-View display, and still use my GPS. And based solely on the number of complaints people have posted about the OEM NAV, I think the Garmin may be a better unit, at a fraction of the price.
  11. benlenz
    31
    <div class='quotetop'>QUOTE(garbageman @ Oct 27 2006, 04:08 PM) [snapback]339716[/snapback]</div>
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 27 2006, 09:21 PM) [snapback]339817[/snapback]</div>
    I have some info if you're interested in this topic, but I decided we should move the discussion to an appropriate forum . . . . here
    http://priuschat.com/index.php?showtopic=25994
