Possible to disable the EV mode 'growl'?
Discussion in 'Prius c Technical Discussion' started by Ghoti, Feb 26, 2013.
  1. Ghoti
    Ghoti Member
    101
    Arizona
    Unlike the full-size Prius I used to have, the c seems to have a speaker somewhere under the hood which makes a buzzing/grinding noise when the car is powered by battery rather than by the engine. Is there a relatively simple way to disable this? I miss 'stealth mode' actually being stealthy.
    Dylan Murphy likes this.
  2. jdz
    jdz Junior Member
    Pasadena, TX
    Check out this thread
    Vehicle Proximity Notification System (VPNS) | PriusChat
  3. ZPriusv5
    ZPriusv5 Junior Member
    74
    Cincinnati, Ohio
  4. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    I put this in the earlier thread. Did it on my C, easy. " It is not under the bumper as some have said. It is easily seen under the hood behind the driver's side headlight. Look for a white two wire connector on what looks like a speaker and unplug it. Easy peasey."
    XCHII
  5. kingnba6
    kingnba6 Active Member
    1,013
    241
    NY
    i still have to do this mod. simple. ill have to check it out
Loading...
