Possible to drive 2006 prius never replacing hybrid battery.
Discussion in 'Gen 2 Prius Main Forum' started by Windysurf, Jul 18, 2019.
  1. Windysurf
    Windysurf New Member
    Frisco TX
    Is it possible to drive an 06 prius without ever replacing the hybrid battery?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Simple answer : No
  3. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
    The hybrid battery is the power to start the car, so you could NEVER turn it off.
    The hybrid battery is the sink for the regenerative brakes, so half your braking system would not work.
    You will find that the Atkinson cycle engine is completely gutless, your Prius will be MUCH less quick. 0-60 in 30 seconds instead of 11 seconds.
    For all practical purposes, no. In most states, it is not legal to fuel up with the car running.
    Skibob likes this.
    49,575
    i have to disagree. i have driven all 3 of my prius without ever replacing the hybrid battery
    strawbrad likes this.
  5. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Your question is too vague.
    Skibob, Raytheeagle and jerrymildred like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,518
    14,121
    Tampa, FL
    Welcome. To combine the various possible responses to the vague question, the answer would be, "Yes, but only if the hybrid battery never fails." ;)
    Skibob and fotomoto like this.
  7. Rmay635703
    Rmay635703 Senior Member
    2,596
    1,613
    Somewhere in Wisconsin
    2013 Chevy Volt
    Install a 12 volt starter so you can crank?
  8. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    The answer is no. You have to have at least a semi working battery with enough power in it to start the engine. If you want a car with the same size engine and no traction battery buy an old Scion.
  9. fuzzy1
    10,194
    Between finding a place somewhere to mount and engage it, and reprogramming the ECUs to accommodate the new configuration, I can't image this could possibly be cost effective compared to buying a new battery. And it would still perform terribly compared to a properly working Prius.
    Skibob likes this.
  10. jerrymildred
    11,518
    14,121
    Tampa, FL
    True, but I got a strong smell of sarcasm from his comment. :D
  11. mgbmg
    mgbmg Junior Member
    Boston
    Hard to believe... my 2006 Prius has 37,000 miles. Is age or mileage the greater predictor for HV battery failure - should I be concerned? Also ... I purchased a "BlueDriver" OBDII link for my gf's Turbo S VW Beetle; she left for vacation, sending it to me for my Gen II Prius. On first blush I am disappointed with the readouts. Is there a better one I should consider or look into this one further?
  12. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
    Heat is the greatest predictor, but between the two you chose, age.
    Boston should not be as hot as long as many areas are.
    Mileage is not a great predictor, as more mileage implies more time being charged, which is good.
  13. bisco
    49,575
    welcome!
    unfortunately, yes. a battery used that little is a negative, not a plus. really, there's no point to owning a hybrid if you don't drive much.
    get dr prius, hybrid assistant, torque or tech stream if you want to monitor the battery. do not leave them connected full time.
    the good news is that for $1,600., you can toss in a brand new battery when the time comes, and you'll almost have a brand new vehicle.
    all the best!(y)
  14. bisco
    49,575
    another one hit wonder?
  15. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Auto Enginiuty does a good job on battery modules as well, with the Toyota expansion.. I still have my 06' prius with the same battery pack
    still runs at 60 SOC most driving, and still charges back quickly. Now that I found out the battery fan is NG, I'm in a rush to get that fixed
    and save this 13 year old pack...
    With Auto Enginuity one can even plot the BTV or BTA's and SOC's or even temps etc. in real time...
    It outputs an excel file of the plots.
    I once made a 3D plot of all the above along with MG1&MG2 rpm's and temps during a 15 minute ride. The file was huge but it worked great! Sorry it only works in bimbos...i mean windows.
    This is the ONLY reason I keep an old laptop with bimbos XP on it...We run linux only now.
    #15 w2co, Jul 30, 2019
