Possible to upgrade a 08' Gen 2 backup Camera?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Ryan R, Jan 10, 2020.
Tags:
  1. Ryan R
    Ryan R Junior Member
    Southern California
    I've had a used Gen 2, 2008 Prius (touring Package I think) and was wondering if it's possible to upgrade the backup Camera to have more "modern" features, such as guidelines, etc
    This post bellow said he was able to manage it on a gen 3. Would it work similarly with my Gen2? I'm not the most car technical person out there. Would it require re-wiring the main touch screen?
    Back Up Camera Upgrade (Guide Lines) | PriusChat
    ydpplqbd likes this.
  2. ydpplqbd
    ydpplqbd Active Member
    551
    254
    Good question!!!
  3. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    On the Gen 2, the gridlines are generated using data from the IPA (intelligent Park Assist) package, AFAIK.
    So if your car doesn't have IPA, which I assume it doesn't due to the lack of grid-lines, then you are out of luck. I don't think it is feasible to retrospectively fit the IPA package.
  4. PriusLord
    PriusLord Junior Member
    Georgia
    I know for a fact that you should be able to as far as resolution (you can only get so far) wise but concerning guidelines etc. I would say if you wanted a higher resolution picture and add the features of Bluetooth Aux etc. I would say replace the head unit and get one that has all of these modern features. Here is a video that should give you a general idea of what you would have to do
  5. Galane
    Galane Junior Member
    77
    24
    Idaho
    Use some self adhesive clear plastic film that can be run through a color laser printer to make a little sticker to put on the camera lens? ;)
