Possible to use RAV4 Key for '16 Prius Four?
Discussion in 'Gen 4 Prius Main Forum' started by afriedma, Mar 20, 2017.
  1. afriedma
    afriedma Junior Member
    Seattle
    I'm looking to replace a lost '16 Prius Four key fob, and I'd much prefer something less bulky. On eBay, I see several items such as, "OEM Toyota Rav4/Prius Key Fob Alarm Remote Transmitter HYQ12BDM H-CHIP R6". When I check vehicle compatibility with the eBay tool, it claims compatibility with the 2016 Prius Four.
    Has anyone had experience obtaining and programming such a key? If so, I'd love to hear about it. I would so much prefer to carry around this little key instead of the giant fob.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Check with a locksmith who does car FOBs.
    I believe some of the earlier Prii had actual keys with chips in them; not so anymore.
    RCO likes this.
  3. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    The RAV4 key is probably compatible. I'm using a Prius Gen3 key with my wife's Lexus 200h for the same reason. The Lexus keyfob case is larger, while the circuit board inside it is exactly the same as the Prius keyfob. But the mechanical key is different.
    If the eBay key is used, then you'll need a seed reset to register it. This is a dealer or locksmith job - you can't do it yourself.
    RCO likes this.
