Possible undiscovered performance and MPG issues with Prius v (lowercase v)
Discussion in 'Prius v Fuel Economy' started by kirill626, Mar 31, 2015.
  1. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I never said change it late, I said leave it for the Toyota recommended interval which is 10K miles.
    Not "scientific studies" but there are (Google) references to running an engine in on the internet, some say leave the oil until the first service, some say change it early (mostly US sites) to get rid of the contaminants and others say any contaminants big enough to cause damage will be caught by the filter so no need. One or two mention that changing the oil early or even using synthetic oil with its better lubricating properties will slow the bedding in process.
    e.g.
    Frequently Asked Questions | Honest John
  2. David Taff
    David Taff Junior Member
    San Diego, ca
    2014 Prius v wagon
    I have “trailer” Prius v5 2014
    average MPG indicator is about 8% high. I get 35-36 mpg (ave indicator is 37-38) no matter how I drive. its as if the car is programmed to deliver 35-36 mpg
    Southern California driving
    #42 David Taff, Jul 4, 2015
  3. kirill626
    kirill626 Junior Member
    27
    32
    Los Andgeles
    I still did no advance with my Prius v (lowercase v for the Prius v wagon) 5 “trailer” project. I have decided to work by excluding possible root causes.
    First
    • Engine. I found a 2014 Prius after rear accident and bought an engine from it. I know for sure that Prius had less than 10K. I have installed it to my Prius. However it didn’t change anything. But on the positive side I excluded engine as one of the root causes.
    • Battery. Last year, I have installed another battery from another Prius v5 (not “trailer”). And again it didn’t change anything.
    • Brakes. I turn them off on the open road just to validate if they have any affect. No changes.
    What left to validate. It is not a lot.
    • Transmission. Yes, I have already installed another transmission, but I am not sure what kind of transmission donor I got. Was it from Prius without trailer or not? Anyway, I am still trying to figure out since my Prius even with another transmission drives the same. I would like to change transmission again.
    • Inverter. Again, I already changed it but I can’t say 100% that the another inverter I have installed is from Prius without trailer. Well, this is something I would have to test and change again after another transmission.
    • And the most important is main engine computer. I thought that all software lays in power management control ECU. But I was wrong. Replacement of power management control unit didn’t change anything. Meaning I need to change engine ECU. For now I still have no idea how to do it. There is a direct link to the keys and I don’t want to mess with it.
    Anyway the issue is still exist, as there is big difference between cars.
    P.S. I had a chance to drive many 2012 and 2013 Camry Hybrid and I noticed that all of them drive consistently good.
    LA - > Sacramento -> LA
    #43 kirill626, Jul 7, 2015
    David Taff likes this.
  4. alekska
    alekska Active Member
    435
    138
    Atl
    Krill, you have probably done most part swaps any Priuschat member ever did.... I do not know what else could be the cause. Body? brakes? Alighnment? Is there any way to check what plant the car was built on ? I think there are 2 plants in Japan that make Prius
    Alex
  5. Air_Boss
    Air_Boss Senior Member
    4,262
    1,197
    New Yawk
    Aha. So this is a Franken-Prius v?
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Wow! That's a lot of work! I was surprised to see you have the larger and much prettier wheels on your v since you seem to be all about the mpg. Beautiful car and good work for the Prius community
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,989
    Texas Hill Country
    I have some simple questions, but I will avoid the backlash.
  8. bisco
    52,918
    wow, that's a lot of work.
  9. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Maybe not all of the vees like the air in Los Andgeles, and some areas are hillier than others. Also, some of them were made specifically for trailers.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
  11. Stevevee
    821
    224
    Vermont
    Maybe mine's starting to go. My last tank was 46 mpg, and I'm over 50 mpg now after 180 miles, 90% highway driving too.
  12. mikefocke
    4,083
    1,865
    Sanford, NC
    Mileage on a per fill up basis varies according to when the fuel shut off occurs. Just after you get a very high number tank, you will often get a low number. For example, my last 2 were 63 and 25. All you should do is look at long term averages, a single tank can vary too much depending on how much actual gas got into the tank.
  13. bisco
    52,918
    63 and 25?!?!?
  14. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Yeah, huh!
    63 I think is impossible for a v to average for a full tank, and 25, heck my wife can't even get as low as 25 and she tries hard. Lol.
  15. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    63+25=88/2=44 assuming equal miles on both fill ups.
    So the point is, that single tank MPG stats can vary surprisingly because of fuel cut off inconsistencies leading to fill ups that don't fill the tank to the same level each time, but the average over time evens that out.
    44 MPG for a Prius v (over two fill ups) in the summer sounds about right.
  16. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    My wife's Prius v is getting 35 mpg this summer. Lol. Oh well. Pumping ac non stop, she keeps a load of stuff in the trunk too which I keep telling her about... And a 9 miles varying elevation commute with multiple stop lights.... Not the best combo and I don't think it's possible to get much worse.... Although loads better than the 17mpg in the 4wd RAV4 we had...
    And sorry but no way that there can be a 38mpg difference in one calculated (not displayed) tank to the next (difference between 63 and 25) just due to maybe at most an extra quarter to maybe if pushing it half gallon or so pumped due to pump shut off inconsistencies. Just not possible. I'd say at most maybe a couple to a few mpg difference per tank if imagining worst case scenario one tank was under filled a half gallon and the next tank was over filled a half gallon.
    But most counties have a weights and measures dept that routinely inspect and test all gas stations for These things. Big fines if they are set up to cut off early and not provide you with what you paid for..
    Maybe a top notch hyper miler might be able to squeeze 63 mpg out of a v for a stretch but I don't see how it's possible to do for for an entire tank! Add 5% minimum due to indicated mpg vs calculated mpg always being high and that would require 66.5 mpg displayed on the mfd for the entire tank.
    And in regards to the 25 mpg! Wow, maybe if you are running rally cross all day non stop....
    #56 Blizzard_Persona, Jul 19, 2015
  17. Markee
    Markee Member
    336
    South Florida Broward County
    Before I got my Prius I had a Ford Ranger truck i bought new in 93 I had the truck for over 20yrs crazy can't believe I owned the vehicle that long.
    Anyways I always filled it up from day one and the truck constantly got approximately 250 miles to a take full for 20yrs didn't make a difference what pump what station.
    Then last year got rid of it and bought a 2010 level 3 was getting just under 400 miles to a tank full traded it in for a 2013 level 4 filling it at the same pump everything the same but only getting like 300 to 320 at most to a take full ?
    I prefer to go by what I get from a tank full because that's what counts for me.
    #57 Markee, Jul 19, 2015
  18. schmuly
    schmuly Member
    209
    51
    BC
    It could have been the way the gas nozzle was in the tank, it clicked off too soon so one tank wasn't exactly full.
    kithmo likes this.
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I agree, my last fill went all the way to 34 litres without stopping then cut off, after letting it settle a few seconds the next click took it to 38.5 litres another 4.5 litres. That would have given me 56mpg compared to the real 49 mpg (UK gallon) for that tank.
    To get 63 for one tank and 25 for another one must have only been half full.
    My average is 47.7 UK mpg or 38 US mpg, about 80% city driving 3 mile commute.
  20. bisco
    52,918
    i have never seen that kind of variation, even with my bladdered '04 and '08.
