Possible undiscovered performance and MPG issues with Prius v (lowercase v)
Discussion in 'Prius v Fuel Economy' started by kirill626, Mar 31, 2015.
  1. mikefocke
    4,083
    1,865
    Sanford, NC
    If you looked at my recent fuelly history, you'd see the 63 and 25. As soon as I posted the first one, I knew the next would vary that way. Maybe I even suspected when the first shut off happened.
    Of course the nozzle angle had something to do with it.
    And these weren't big fill ups, I tend to refill at about the 5 or 6 gallons needed point. So even a half gallon would have a big influence in the calculated MPG.
    The state cares not about the shut off point beyond safety, they do care about the accuracy of the billing and in both cases it was spot on.
    This wasn't the only time such a wide disparity occurred back to back.
    My only point in posting was to suggest that averaging over several tanks probably gives you a truer readout of your MPG than a single tank calculation would.
    kithmo and bisco like this.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Without a doubt
  3. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    Correct. Be sure you're dividing total distance by the total quantity of fuel consumed in that distance. Some people try to figure average mpg by averaging a series of mpg results. That method won't yield the correct average---although it might be close if you buy close to the same amount every time. A similar precaution applies when you're calculating the average discrepancy between actual fuel economy and the number shown in the display.
    SageBrush likes this.
  4. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Understood, and you are absolutely correct. Long term average is the way to go... :)
    I though I read somewhere that fuelly can now disregard the outlayer really really high (possibly a mistake in input numbers by user) as an option to get more average and appropriate data?
    I do remember seeing a persona on fuelly that was consistently low to mid 40's with a crazy high tank for one that was in high 60's or 70's? I should have but didn't notice the miles driven on said "tank" Maybe he filled up just prior to a record short trip, then filled up again and posted his fuelly numbers? But that shouldn't skew the average as it is an average? Right? Either way one can't consider that a "full tank average" but it will get imputed into fuelly...
    Kinda akin to me filling up prior to this trip:
    Then refilling and posting this average (very abnormally high due to perfect conditions and rolling hills) as my "tank full" average, when it was really only for a trip...
    Either way.... Let's roll on...
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ just in case CR94's point is not beaten to death yet,
    he is pointing out that a weighted average is required for fill-ups of different amounts.
    Or, for the lazy amongst us: total_miles divided by total_gallons
  6. bisco
    52,917
    thanks, i thought i was gonna have to get off the sofa for that one.:cool:
  7. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    And I agreed. Read first line of my last post....
    Heck I keep all my gas receipts and break it all down in all the ways I can. Lol. So I understand.
    Was just reitterating that short trips can't be used for "tank averages" as it seems some folks have been claiming outrageous averages when in most likelihood it is due to an extremely high mpg trip and not a full tank average....
    That's all I meant.
    Goodnight...
  8. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Maybe the major recall on the ,,V,, will cure the gremlin some have
  9. bisco
    52,917
    maybe it will rein in his non trailer v's.:cool:
  10. 2nd gen owner
    2nd gen owner New Member
    idaho
    With regard to the 'trailer cars', how about this: I've read about and noticed myself the change in the engine tone and power about 30 second after it has started. This is when the engine changes from the 'otto' cycle to the 'atkinson' cycle mode. It is done by controlling the valve timing. What if the 'trailer cars' have a problem with the valve timing control?
  11. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Can't imagine that. All uphill on the second tank?
  12. mikefocke
    4,083
    1,865
    Sanford, NC
    Nothing to imagine, the third tank reverted to the 42MPG +/- norm.
    The variation was on a small fill up with an early shut off. Think of the MPG effect of a 5-6 gallon fill up on calculated MPG if the shut off was a half gallon early.
    All I'm saying is calculate over a larger sample of fillups. One allows for too much variation.
  13. Stevevee
    821
    224
    Vermont
    True, with such a small tank, even .3 gallons has a dramatic impact, the law of small numbers. My mileage the last 10 fillups is over 43 mpg, and I wasn't even trying, nor are my tires at my preferred psi levels. Backtracking over two years, breaking out the cold months, in a moderate to warm climate, my overall lifetime mileage would be at the 43/44 range, and that doesn't take into account the hills we have, which would probably add somewhere in the neighborhood of another 2-4 mpg. Geography and climate has a huge impact on hybrids.
  14. pachocco1
    pachocco1 Junior Member
    Austin, TX
    2015 Prius v wagon
    kirill626,
    New to Hybrids, Prius, and this forum (first post). Thank you for sharing your experience and concerns.
    Looks like fun items to isolate for root cause.
    Have you checked for spun or bad bearings in the wheel hub, CVT case, or drive shaft(s)?
    kye04 likes this.
  15. kye04
    kye04 Junior Member
    38
    Europe
    Any news? I have a prius + with "trailer" effect. I also have a 2010 prius and i remember i had the same problem . I changed the rims from 17 to 15 and the oil from 5w30 to mobil1 0w20. The car changed alot. Yet the most important and strange change was when i exchanged the 0w20 mobil 1 to 0w20 eneos....best consumption ever....
    the days i"l change the oil from my prius plus (i bpught it with 5w30 ) with eneos 0w20 ....
    I'll keep u posted....
    David Taff likes this.
  16. kirill626
    kirill626 Junior Member
    27
    32
    Los Andgeles
    Hi - I continue patiently looking for the reason of different ways Prius perform. On all the questions there is one simple and unpredictable answer - final gear ratio. Transmissions gen 3 and in Prius v (lowercase v for the Prius v wagon) Wagon are the same except for this final gear ratio - 3.27:1 vs 3.70:1. I purchased from v 2013 one more transmission from an accident car. I don’t know how did that car performed before – trailer or not :) I dissembled transmission and in details learned all important things. I was able to confirm that it has final gear ratio 3.70:1. Now I plan to check my current transmission and old one I removed. Both transmissions performed pretty badly – as a trailer.
    I am pretty sure that the difference between "trailer" and normal Prius v is in transmission. However, I still can’t proof it but for sure I am going to the right direction :)
    80/22=3.636
    55/54=1.018
    3.636х1.018=3.70
    bisco and David Taff like this.
  17. AMP
    AMP April 2012
    Chicago
    Rehm94 I posted this just recently I have a 2012 v Three and usually get 40+ mpg. I got new all season tires in August and MPG dropped to 35 MPG. The last week or two, the MPG is back to 41.
    Folks talk about the 12V is easy to measure. Are we just talking about using a DVM on the battery or test points?
    I would wonder how that effects MPG?
  18. kye04
    kye04 Junior Member
    38
    Europe
    Do the following : find prius without trailer , get it's VIN and your VIN and go to a program like Autodata and check if the components codes of the gearbox are the same ....
    Also, being a E-cvt gearbox it's ratios are controlled by ECU. Might be the same gearbox but with different version of software. To be certain do the comparation i told u ....
    If i remember well u told us u switched engines and gearboxes from non trailer to your car....nothing changed...
    I think the answer is the software....
  19. kirill626
    27
    32
    Los Andgeles
    Transmission inside does not have any software. Prius has a very simple transmission, and I would say the simplest of all that I have met before. Even thought Prius transmission called CVT it wasn’t build that way. Final gear ratio fixed number 3.70 for Prius v (lowercase v for the Prius v wagon). Same transmission for gen 3 Prius uses 3.27 final gear. Possibly that by mistake in some Prius v (lowercase v for the Prius v wagon) installed incorrect final gear 3.27 and this can explain "trailer" effect for some Prius v (lowercase v for the Prius v wagon).
    All computers I changed already from non trailer Prius v (lowercase v for the Prius v wagon) and didn’t give any positive results.
    PS I do not have a history of transmission which I installed in my Prius v (lowercase v for the Prius v wagon).
  20. bisco
    52,917
    yes, you have to test it in the morning before driving, without opening the drivers door.
