Post-cat EGR on Gen IV - Carbon fouling like Gen III?
Discussion in 'Gen 4 Prius Main Forum' started by jburg, Sep 17, 2020.
  1. jburg
    jburg Member
    93
    RTP, NC
    So after looking into both the 2017+ Camry (A25A-FKS) and 2019+ Corolla (M20A-FKS) I have come to find out that Toyota has incorporated an EGR cooler and valve that is fed with exhaust gases post-cat as is done with the Gen IV Prius. I have never been under the hood of a Gen IV, but it looks like on the Corolla that Toyota seriously redesigned this system (from the Gen III) and the recirculated gases are fed into the cylinder head via an additional manifold plenum that sits in front of the intake manifold. This is most likely to reduce the clogging of the passages noted in the Gen III.
    Question: Has anyone had their GenIV Prius EGR cooler and valve off for a PM? How bad is the carbon fouling? Mileage this was done?
    Thanks!
    SFO, Merkey and amos like this.
    49,694
    so far, all is good from what i have read
  3. jburg
    jburg Member
    93
    RTP, NC
    I found another thread where it was clogged at 70000 miles (n). You were on that thread:
    Gen4 EGR fate? | PriusChat
    49,694
    ouch, you better reconsider then...
  5. amos
    amos Active Member
    341
    281
    los angeles
    my 2016 has 140k on it , so far no maintenance on the egr, no cleaning, not replaced egr valve, not cleaned intake manifold, no oil catch can installed, never checked it but on the alert because of a bad experience with gen 3.
    Raytheeagle and Merkey like this.
  6. jburg
    jburg Member
    93
    RTP, NC
    Any interest in taking off the tube between the EGR valve and the intake manifold to inspect for carbon buildup?
    Mendel Leisk and SFO like this.
  7. bisco
    49,694
    if you've never checked it, how can you be on the alert? a visual or audible problem could be too late
    amos and krmcg like this.
  8. amos
    amos Active Member
    341
    281
    los angeles
    I THINK I IWLL DO A COMPLETE CLEANING OF THIS WHOLE PATH WHEN CAR GETS TO 150K. right now its too hot for anything
    Raytheeagle and bisco like this.
  9. bisco
    49,694
    i'll try to blow some of our frigid air out your way :)
    amos likes this.
