Post,Gen.2= Who still has the original Hybrid battery-How many miles
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jan 13, 2020.
  1. JahT
    JahT Member
    145
    77
    2008 195k miles original hybrid battery, probably on 2nd or 3rd 12V battery.
    And "HA!" to all the naysayers in 2007-8 that said I'd be stuck paying thousands to replace it.
    Data Daedalus likes this.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Ironically there are many PC forum experts who tell newbie posters not to buy a Prius because of its high maintenance costs even though the e parts have one or more Prius’s. Never understood that. Eventually my Prius will fail and I’ll scrap it but until then I have to say that it’s an amazing piece of engineering and a very well built automobile. Millions sold over the past 20 years and most still on the road. Just wish it had a front seat hatch release. Will get to that this year, hopefully on mine. Have to anyway since I need to replace the gooey rear hatch switch cover.
  3. clintonrebel
    clintonrebel Junior Member
    Mississippi
    2005 with 240,000 miles. I’ve not done anything to it but change the oil and tires. And of course the head lamps. Still runs great.
    Rph74, Data Daedalus and Another like this.
  4. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    463
    Leawood, KS
    I
    white 2008. 113K OEM still. lived in PHX
    red 2008 117K OEM still. lived in FL
    both starting to show symptoms...but both are in Colorado where cooler and dry seems to have helped battery life a bit.
  5. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    UK 2008 Tspirit; now at 138,250 miles. Original Traction Battery, replaced the 12v in 2014 - still going strong in 2022. Presently 66.0 mpg (UK) on the MFD using E5 Super Unleaded. Getting much less with E10 fuel. Daily driver with 170 mile commute per week. The “Spaceship” is still going strong - totally in love with this over engineered piece of astounding automobile technology.
    iPhone ?
  6. gramps
    gramps Member
    195
    44
    Southeast Texas
    2009 original owner coming up on 130k, original battery
    My 1st post in many , many years.
  7. gramps
    gramps Member
    195
    44
    Southeast Texas
    I left out located in San Diego, only driving out of SoCal once for a 3 day Las Vegas trip.
    I might be moving to Tx and selling her in the next 2-4 months if my daughter doesn't want her
  8. Another
    1,819
    517
    Naples, Florida
    Why selling it now?
  9. yossi
    yossi Junior Member
    61
    What does the "deep cycling/reconditioning involve? Is it a software solution or does it involve physically opening the HV battery?
  10. Turlin
    Turlin New Member
    central MN
    228,000miles, 15 years on original hybrid battery, then had a module failure. Replaced the failed module and it appears to be back to normal (been 2 weeks so far)
    I'm the 5th owner of the car (2 dealers in between 3 real "owners"), and Carfax report and dealer indicates that the previous owner drove it down from Minnesota to Texas every year for the winter.
    Planning to pre-emptively replace the hybrid battery with one from NewPriusBatteries and sell the original modules. I plan to drive the car into 300,000miles, and don't want to deal with module failure events that will be statistically more likely the older the battery gets.
  11. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    No, it is not a software solution.
    Yes, you do have to remove the trim to get to the electronics bay the first time you recondition to install the wire harness you will need to connect the charger/discharger to the battery (much the same idea as installing a 12 V battery quick connect plug), but after that, it is just a plug-and-play deal.
  12. johnHRP
    johnHRP Active Member
    644
    187
    KA, DE
    Excel
    2006 Original battery went bad in 2017 March 210k miles. Refurbished battery lasted 2 years but good enough for $800. I junk it now because the AC evaporator leaks and need 14Hours labor to replace. For the first 10 years everything is normal, catalytic converter went bad at 180k miles in 2013 June. I lived in FL and no garage. Oul consumption 0.5 quart every 5k miles.
  13. Roundgunner
    Roundgunner Junior Member
    SE CT
    2009 157,000 original battery.
    I did the 12v once, tires and windshield wipers. Changed coolants at 100K oil every 10K.
    I use it like a mini truck, hauling about 1000 lbs most of the time. 75mph average but only get about 45mpg
    Still runs great.
  14. Laura Billings
    Laura Billings New Member
    Virginia Beach
    My 2014 is at 300,000 original hybrid battery. I love this car!
    Data Daedalus and bisco like this.
  15. FazilHussein
    FazilHussein Member
    71
    36
    Perth, Ontario, Canada
    2005 prius; 396k km => 246k miles, original battery. 2nd owner, bought with 38k km in 2012. Still getting 5L/100km, minimal maintenance.
    Data Daedalus and johnHRP like this.
  16. Kiwi7910
    Kiwi7910 Junior Member
    50
    New Zealand
    190,000km in a 2007. Original battery and untouched!
    No error codes, but I am planning to take it out and recondition it sometime in the next week, with the hope of extending it's life a little further...
  17. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    my 2009 has just under 300,000 Miles.
    It has the original hybrid traction battery but its on its 2nd 12 Volt since my ownership.
  18. Data Daedalus
    1,025
    1,185
    Wembley, London
    2008 Tspirit (UK).
    Now at over 151k miles.
    Still on original traction battery and the only replacement 12v battery was installed in 2014.
    Do approximately 170 miles commute per week.
    Running on Esso Synergy Supreme E5 (Super Unleaded) +99 RON fuel.
    Avoiding the E10 fuel being foisted upon us in the UK - very low quality rubbish. Makes the engine labour and vibrate, E10 burns off quickly with much less range and dreadful MPG.
    I don’t trust UK E10 fuels.
    Otherwise, the “Spaceship” continues to roll along, day after day.
    iPad ? Pro
    johnHRP likes this.
  19. nolotank
    nolotank Junior Member
    33
    23
    United States
    2008 with 116,000. Just recently completed a San Francisco to Dallas round trip with no problems, very grateful for my car.
  20. Kenny94945
    Kenny94945 Active Member
    850
    426
    Sausalito
    2016 Prius v wagon
    What a great question, thank you OP.
    With a quick read, I'd conclude time of 20 years is not out of the question for the hybrid battery life.
    Mileage seems to vary in the responses, with many still on the original at 200K.
