Post ICE coolant change - advice needed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bugaboo416, Nov 1, 2019.
  1. bugaboo416
    bugaboo416 Junior Member
    US
    I replaced my ICE coolant about a week ago. I used a multimeter to jump the CHRS pump. I got it to 4.20 .
    I tried putting the prius in maintenance mode and bleeding the radiator but after 1/2 hour, nothing ever came out. I repeated this the next day and got my multimeter down to 4.16 but still nothing from opening the radiator bleeder valve and running the prius on maintenance mode. I get great heat when I run the AC on Hi. I have coolant in the reservoir level right between Low and Full.
    What I do every morning is check for leaks (none found in a week's time) and add coolant to the top of the radiator cap before driving the car (~20 miles each day total) I usually add about an inch of coolant each day. This has gone on for 5 days so far.
    My question is: If I continue doing this each day, will it get to the point where the radiator cap will stay full after another week or two of this routine or should I retry the pump/radiator bleed combo?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Just keep checking the radiator cap and top up as needed;).
    If you have an idea of what you drained out, you’ll now have your target of what to refill to:).
    Once close to that, you’ll know your close or done(y).
    SFO likes this.
  3. bugaboo416
    US
    Thanks Ray. I needed that affirmation that I'm doing right by the car, esp. with my first coolant change.
  4. Patrick Wong
    18,200
    6,493
    All good. Don’t be afraid to fill the reservoir to the full level.
    Raytheeagle likes this.
