Post mortem hybrid battery questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 1904, Apr 19, 2023.
  1. 1904
    1904 New Member
    Greeley CO
    Okay, so my Prius is at 116K and the hybrid battery is dying. After several hundred dollars worth of “diagnosis” I know only that “some of the battery block voltages are lower than others in freeze frame data”—in other words, the dealer told me nothing.
    So here are my questions:
    1. Now that the gas engine runs all the time, does the hybrid battery do anything besides initial ignition?
    2. Which of the car’s readouts still approach being accurate?—
    a. energy monitor
    b. hybrid battery status
    c. hybrid system indicator
    d. distance to empty readout
    Not really looking to replace the hybrid battery, as the brakes and sparks are almost shot and the driver-side window no longer opens, but I’m curious as to whether there are dozens or hundreds of miles left on this thing. TIA!
  2. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Hundreds of miles. Don’t rely on any of those 4. The HV bat starts the gas engine by initiating rotation, so it’s essential. But if you’re ok with the gas engine doing all the work you can probably skate by with a “bad” but not dead HV bat. However your days are numbered. I’ve run one of my Priuses in probably the same or similar condition for maybe 3000 miles and 4 years.
  3. ASRDogman
    ASRDogman Senior Member
    7,896
    4,015
    You could try the Prolong System to revive the hybrid battery.
    Something you can install yourself with a few simple tools.
    And some mechanical ability.
    It's about 4 or 5 times less cost.
  4. 1904
    1904 New Member
    Greeley CO
    Thanks. I was figuring that if all the hybrid battery does at this point is start the car, then I probably still have a few months left.
  5. PriusCamper
    PriusCamper Senior Member
    13,200
    5,346
    Pacific Northwest, USA
    If you buy an OBD2 reader you can clear the error codes as they come up with a phone app like Dr. Prius App... And you'll be able to go for weeks or months before the pack starts running too hot to keep using. Here's buyer's guide for OBD2 reader: Hybrid battery diagnostic and repair tool for Toyota and Lexus I've had packs I've diagnosed in my car and done this routine many times. Electricity behaves oddly too... Some days I'd clear error codes several times in a day and then sometime I could go weeks without an error code.
    Also some people luck out and replace one of the 28 modules, which cost $35 each used and then get a year or longer without issues.
  6. BiomedO1
    BiomedO1 Senior Member
    4,347
    2,282
    Left Coast
    I would replace the spark plugs, air filter, clean out throttle body, traction battery cooling system - if your handy. This will extend the life of the car and give it a chance to be reliable - since your on ICE much more of the time.
  7. CatNinja
    CatNinja Member
    70
    46
    Hawaii
    2023 Prius Prime
    XSE Premium
    FYI, I had similar hybrid issues to you. Here’s my experience if it’ll help you in a decision.
    I built an DIY grid charger and did a 3 cycle recondition. That fixed it for a few months before block 9 kept failing and I had to reset using Dr Prius on almost every trip. Note that the SOC resets to 20% or so, so even though you can still run, the engine will kick in continuously and will overcharge the battery, causing it to heat up very quickly. You may have to pull over to let it cool down so you don’t destroy your battery.
    I bought 5 modules from eBay for $30 each, intending to replace a module from block 9. Turns out I had 3 modules that were failing (capacity < 1.5Ah), and 2 of the eBay modules were weak (capacity < 3Ah), so I ended replacing 3 modules. It’s been working great so far for a couple of months. Car runs like it did before the hybrid error. Next time I would get modules for a reputable dealer recommend in this forum, instead of an unknown eBay seller.
    Spark plugs are dirt cheap and straightforward to replace, though painful because you have to take off the cowling on a Prius.
    Same for a window motor. Relatively cheap and very straightforward to replace if that’s your issue.
    Prius brakes last a long time. I’m still on my original at 130k and 13 years. Not sure what you mean by almost shot. But there is a known brake booster problem that you can get fixed for free if your car is < 10 years and 150k (which you are well under at 116k).
  8. 1904
    1904 New Member
    Greeley CO
    CatNinja: Appreciate the advice, especially because I was curious as to whether short trips (~5 miles) or longer trips (~50 miles) were more dangerous.
