post pics of your prius w/ rims!!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mrplease, Sep 8, 2008.
  1. illprius
    illprius Junior Member
    36
    17
    Love everyone's wheel set ups and I hope my posting here brings this thread back to life. Well I'm going to be trying something completely different I'm going to be trying to fit 17x8.5 corvette c4 "sawblade" wheels on with adapters. Planning on rolling the fenders and coilovers. Hopefully to have pics of progress of wheel fittment. Wish me luck!!! Plus don't care about losing MPG I drive 15 miles a day if that.
  2. madmarc
    madmarc Junior Member
    Graz / Austria
    Specs:
    - BC Racing coilovers, ride quality like a car with stock european suspension
    - 18" Enkei RPF1 Design wheels, silber flake power coated , high gloss polish finish with Hankook S1 Evo 205/40 18" Tires
    - yellow fog lights
    - black badges
    This car is daily driven.
    [​IMG][​IMG][​IMG]
    Deemo, Daves09prius and Justdidit like this.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Wow! Very Clean. I also looked at the RPF1 wheels. Nice choice on size...especially since the are fairly light compared to most 18" wheels. How much of a MPG loss did u experience as you only went with a 205 tire unlike my wider 215?
  4. Deemo
    Deemo New Member
    Looks great! :D
    Makes me want to get coilovers ASAP. (y)
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Post up pics when ur done...this is definitely different...
  6. FishCandy
    FishCandy Active Member
    220
    292
    19 x 9 SSR SP3
    marvingloria2011 likes this.
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Very clean... (y)
    FishCandy likes this.
  8. Doc Willie
    1,717
    144
    Out there, somewhere
    Been away too long. Missed this thread entirely.
    Jon Senum and Gorilla97 like this.
  9. Gabby
    Gabby New Member
    nice!
  10. Michael325
    Michael325 Member
    85
    57
    Central Valley CA
  11. Cezarcaz
    Cezarcaz Member
    102
    49
    Chino
    iPad ?
    marvingloria2011 and F8L like this.
  12. biggadgetman
    biggadgetman It ain't easy being Green!
    Dallas, Texas
    Sezy and Justdidit like this.
  13. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Any issues with the Gen3 wheels? Direct bolt on? I've been thinking about either taking the wheel covers off or getting Gen3 wheels for my Gen2… VERY NICE looking Gen2 you have
    DelBoyTrotter likes this.
  14. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    5x100 - perfect bolt up match. Those particular G3 wheels are actually a bit heavy compared to the 15" or 16" we use on the G2. You will notice a loss of mpg's but honestly it would be worth it to me - that G2 looks awesome with the package 5 wheels. Good luck finding a good deal on used ones. I've looked - they're not cheap.
    DelBoyTrotter and Delta Flyer II like this.
  15. apdevelopments
    apdevelopments Junior Member
    Just wondering what the tire size will be on these 19x9 wheels.
  16. ucsbwsr
    ucsbwsr Active Member
    105
    145
    Put a deposit down on a local set of wheels, brought one home to do some fitment testing, I think they will work with some different tires.
    SSR Professor SP1 18x8.5.
    Evan
    [​IMG] [​IMG] [​IMG] [​IMG]
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Cool! It will be interesting to see if you can tuck that wheel in the front fender w/o rubbing once you lower it.
    Here is a Gen3 with the SSR SP1s running 215/35R18s
    http://minkara.carview.co.jp
    #317 Justdidit, Mar 23, 2015
    Salubprius likes this.
  18. sidecar
    sidecar Member
    342
    45
    Australia
    have you still got the spacers on ?
  19. ucsbwsr
    105
    145
    Jeremey, It should be pretty clean when it is all said and done.
    *edit*
    I plan on running 225/40/18 V12s unless that ad for Toyo T1Rs isn't dead.
    #319 ucsbwsr, Mar 23, 2015
    Justdidit likes this.
  20. ucsbwsr
    105
    145
    Not in these photos.
    My spacers for the stock wheels are 15mmF and 25mmR, I would like to try and run the 15mm on the rear SP1 because that would give it absolute flushness with the fender (flush is my goal) but pushing the rear out that much will create some other problems with rubbing and will likely require me to dremel some of the metal body where the body meets the rear bumper, there will be trimming of the bumper and liner as well. I won't know until I get the new tires, and lowering spring installed. I also may buy a 10mm spacer as a precautionary backup.
    The front won't/can't take a spacer, it pokes maybe 1-2mm. Although there is some extra back-spacing between the strut and wheel to accommodate a 9" up front, things get tight when turning at a full lock. I tested with this 255/35 Eagle F1 and when turning to the right the edge of the tire would catch the liner (turning to the right the rear of the tire was fine). I think this will be alleviated with the new tires as it was only a few MMs of clearance and it was right at the forward/outer edge where the new tires and their narrower width and tidier sidewalls will make all the difference.
    Evan
