Post Your Stats on Fuelly!
Discussion in 'Gen 4 Prius Fuel Economy' started by inferno, Mar 29, 2016.
  1. inferno
    inferno Senior Member
    1,072
    405
    EPA can have their measurements! And the user community can have theirs!
    Toyota Prius Mileage | Fuelly
    Not much on 2016 data but so far it's showing a 24% improvement on average compared to last gen, 55.8 average mpg vs 45.1 2015 (more stringent EPA tests, right?)
    Overall though - that's amazing. The lowest mpg on a 2016 I see is 48.4 - which is saying a lot (Cold Weather I bet, short distances, etc...)
    Mendel Leisk and krmcg like this.
  2. krmcg
    2,592
    2,393
    Whittier, CA
    Fuelly Fan here...
  3. ucla107
    ucla107 Member
    98
    107
    Four Touring
    Not enough miles to post yet but here it is for my "first day" with the Prius... Mostly freeway miles (about 8 miles each way was not freeway)
    #3 ucla107, Mar 30, 2016
  4. altdel
    altdel Member
    70
    36
    Danville, CA
    Another Fuelly Fan...
    krmcg likes this.
  5. bwilson4web
    16,554
    I would also recommend sharing with Fuel Economy that has a 'user mileage' option. The reason is to reach non-technical readers who might not know about fuelly.com. It also gives the EPA a 'heads up' on the quality of their Monroney (window sticker).
  6. Marshmallow
    Marshmallow Junior Member
    i have a question about fuelly. first time using it, so i apologize if my question is bad. i filled up my tank yesterday, and i want to input the data today. where it says "miles since last fill up", do i input how many miles i've driven so far on the gas tank or the odometer reading?
    i'm guessing it's the odometer reading, but i just want to confirm.
    also, if it is the odometer, i've driven over 200 miles since i filled up, will i input the current odometer reading, or the amount that it was prior my fill up (which is 200 less)?
    thanks in advance!
  7. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I added in mine (to my signature as well) but only having to fill up about 1/2 as much as my previous car thanks to the great MPG numbers I am getting.
    krmcg likes this.
  8. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Added
    krmcg likes this.
  9. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    The option in Fuel Economy is called "My MPG"
    Welcome to My MPG!
    bwilson4web likes this.
  10. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    How do I get the "Fuelly" stats to show up on this forum??
  11. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    KimPrius3 likes this.
  12. Mendel Leisk
    42,387
    With every fillup you enter what the odometer was reading at the gas station. Fuelly does the math, recalls your previous odometer reading, subtracts it from the current one.
    Having said that I've got a few puzzlements myself:
    1. What happens with your first fillup, when you have no "previous" odometer reading. I'm sure there's a workaround, perhaps for that first report it asks you to enter both the odometer reading and miles (or kms) since last fillup? Sorry, it's been about 5 years, can't recall exactly, but it did work.
    2. I was thinking you could set a preference on Fuelly, to either do the odometer reading, or just enter your tripmeter (or hand calculated) distance since last fillup. But looking now I didn't see anything like that in settings.
    One thing: using the odometer reading from each fillup is the safest way to go, not prone to accidental reset. Trip meters are convenient, and give feedback, how far you've gone on a tank. I do reset the trip meter at each fillup. But they're error prone, things can happen. You can accidently reset them, a battery swap will reset it, and so on.
  13. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    I use the miles since last fill up option since I reset trip counter A. What I've been seeing is the reported MPG is 4% higher than what Fuelly is finding. This is over the course of several fill ups, so I feel reasonably confident using a 4% adjustment, although I have not confirmed the accuracy of the odometer. Nonetheless, I'm amazed every time I get gas and see how little I use.
    krmcg likes this.
  14. Bill Hollister
    Bill Hollister New Member
    Granite Bay, CA
    I am curious about one thing in particular...first I am a new Prius Prime 2017 owner (just bought it used) so I'm certainly a newbie on this site. Second, I have been using Fuelly for many years and with my previous cars I always filled them up (never used 'partial fillup') so felt I was getting a decent representation of MPG. With the Prius after reading multiple threads on this forum I'm thinking that I will try and keep the gas tank at 1/2 and after 500-600 miles add 2 or 3 gallons. So, my question...if I check the 'partial fillup' will Fuelly give an accurate MPG? TIA. Bill
  15. Mendel Leisk
    42,387
    Not sure. Off the top of my head hunch: individual tanks could have wildly inaccurate mpg, but the running average will be increasingly accurate, as tanks accumulate.
