Potential new Gen 2 owner
Discussion in 'Gen 2 Prius Technical Discussion' started by USMC1968, Jul 13, 2023.
  1. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    stepping back, I guess I look at this as an interesting project car. Probably worth $4500 as a pile of parts today. Probably needs a good $3500 to turn it into an 18 year old car that no insurer would value higher than $6k were it to be lost.
    An interesting opportunity, but keep it all in perspective.
    USMC1968 likes this.
  2. USMC1968
    USMC1968 New Member
    Maryland
    Quick question, @ $3,500 if I did most of the work myself with purchased parts (eBay/Amazon, etc) or is that a shop cost guestimate ?
  3. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    In my head, that's you doing the evaporator and a shop doing everything else, (tank, struts, ac charge) including a surprise nobody's found yet. Because there are always surprises on 18 year old cars.
    Oh, and stay the h*** away from eBay and Amazon for autoparts, particularly electrical, ignition & suspension subcategories. WAAAY too many counterfeits.
    donbright and USMC1968 like this.
  4. USMC1968
    USMC1968 New Member
    Maryland
    Cool, good intel thanks I will keep that in mind. yeah, there are always surprises..I might be double thinking this..I have not agreed to the purchase yet, still in research mode.
  5. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    only thing i would add is.. the hv battery cooling system (i.e. a fan + back seat duct ) depends on the AC in the cabin to keep temperatures normal. AC is not a luxury like in most cars, its part of the drive train
  6. USMC1968
    USMC1968 New Member
    Maryland
    awesome thanks, that I did not have any idea about. Good thing to consider before possibly diving into this thing.
  7. USMC1968
    USMC1968 New Member
    Maryland
    I was scouring the service records again and found this about the AC service that was done in 6/2011 when the vehicle had 89, 517 miles. Maybe just needs a recharge or worse a leaky evaporator? That can be big $$$ me thinks. Current owner states the AC has not worked on it since he bought it January 2022, which stinks because it was serviced every 5K miles at the dealer since new (according to Toyota owners site).
    #27 USMC1968, Jul 17, 2023
  8. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    #28 alftoy, Jul 17, 2023
  9. USMC1968
    USMC1968 New Member
    Maryland
  10. bisco
    52,878
    there's controversy here regarding 'a/c part of drive train'.
    some people hook up an obd scanner to watch battery temps, and haven't noticed a difference between a/c off and a/c on.
    others say if you are comfortable, your battery is too. idk if toyota states anything in the o/m.
  11. alftoy
    1,132
    520
    If A/C is part of the drive train, then why isn't the A/C controlled by the drive train. How does the drive train turn on the A/C or shut the car down if it can't turn on the A/C. Doesn't stand to reason.
  12. USMC1968
    USMC1968 New Member
    Maryland
  13. USMC1968
    USMC1968 New Member
    Maryland
    Maybe the cool AC air gets pulled into the batteries by the fan? I know nothing of these Hybrids, hence my seemingly endless questions and I thank you all for your patience and help.
  14. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    The car already had a bad compressor and a bad txv valve. Possibly because of bad ac oil. Not operating now means the root cause all along was a leak. Major repair likely again on a compressor run by three phase power with the windings insulated by the proper oil. This tells me a true hack outside of the dealer has been working on the car.
    Exactly.
    Given the price and hackery, the next balls to drop are the engine and brake booster. I would not give my son this vehicle and expect reliability.
    USMC Vietnam Era
    #34 rjparker, Jul 17, 2023
  15. USMC1968
    USMC1968 New Member
    Maryland
    Good to go, thank you for your service and everyone's input. I think I will pass as suggested.
    Semper Fi
  16. donbright
    241
    151
    33
    oklahoma
    what im trying to say is that heat kills batteries. The batteries are in a box under the back seat. the only cooling they get is a fan pushing air through a duct that pulls from the cabin on the vent on the right hand passenger side. So if that person never uses the AC, and they drive around in places where it's 120 F degrees outside and no AC, parking in a lot where its 130-140 in no shade, windows closed for 8 hours, what are we talking 150F inside that miniature greenhouse? They start the car, no a/c, commute home for an hour, those batteries heat up by nature of their internal resistance during normal operation, so now we are maybe pushing 160-170 on the batteries? Those batteries are going to undergo a lot more heat stress than someone who has the A/C cranked. The a/c is basically the cooling system for the batteries, like a radiator cools the engine.
  17. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    Said person is likely to be dead, never mind the car's battery. With all 4 windows down and a reasonable speed the car might be only 130F inside. People die in short order at those sorts of temperatures unless they are very well hydrated. Maybe even then.
    A more reasonable scenario is 100F outside, all the windows down, and 110F inside. I don't think that would actually kill the pack. It would result in the blower running at higher speeds though. Hot air can still pull heat out of an enclosure, it just doesn't do it as well as cooler air.
  18. USMC1968
    USMC1968 New Member
    Maryland
    Totally get what you are saying and that makes complete sense. I appreciate your input and experience with these vehicles!
    Heat = Not bueno for batteries :)
  19. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    2 minutes of bla bla bla and 0 important information.
    In order to get to the evaporator coil you have to remove everything to get full access to the hvac box. You will have to split that box. The coil is hidden inside of it.
