Potentially Reckless, unethical, incomplete, false and self-serving advice from my Toyota Dealership
Discussion in 'Fred's House of Pancakes' started by Hino, Jan 11, 2024.
  1. Hino
    Hino New Member
    Ridgedale, MO.
    Another thing! .. After my new engine was installed I drove down the street and pulled into a parking lot. After I was treated so poorly by the Service Manager and I had lost trust in them something told me to check things out. I had driven two miles from the dealership and shut the car down and waited a couple of hours ( I had a couple of calls to make ) and popped the hood and checked the oil. The oil was over-filled. Past the top dot and was way up where the dipstick is crimped. What will happen when engine oil is overfilled like this?
    Additionally, the coolant in the overflow reservoir was overfilled up to where the overflow tube enters the reservoir. What harm would this cause? They were extremely unhappy when I asked them to adjust the levels to factory standards. Crazy, crazy stuff.
  2. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    I would have recommended Not asking to have All the fluids changed, whatever your thinking was at the time.
    But you've already been over that bridge so ....
    I'd think you've got a 50 50 chance of winning your disputed charges, keep your fingers crossed, the dealers response doesn't impress your credit card company.
  3. Mendel Leisk
    41,488
    The newer piston rings will reduce the engine’s propensity to burn oil, but the EGR system, including the EGR passages in the intake manifold, will still “reliably” clog up with carbon. I would recommend EGR system cleaning every 50k, perhaps in conjunction with engine coolant changes, though there are strategies to avoid coolant spillage, at any time.
    Have a look at the first two links in my signature (on a phone turn it landscape to see signature). If at all possible, DIY cleaning is the best, most expedient, and (by far) the cheapest method to clean the EGR.
    Hopefully independent garages will step up their ability to help, but I wouldn’t count on it. Toyota seems to be hoping the third gen lemons will go away, and eventually they will.
    In the meantime, 3rd gen owners are being “dropped in it”. Keep that in mind, for the next time you’re choosing a car make.
    Hino likes this.
    51,975
    checking the oil is difficult. it is very clear, hard to see, and can streak up the dipstick.
    check it multiple times, under different lighting and background. go by where the solid part stops, not the streaking.
    the coolant should be removed to the cold level recommended in the o/m.
  5. JC91006
    16,769
    8,567
    Based on all the information you provided about the services, the bank may reverse the charges just because they are out to protect the customer vs. bad vendors.
    However on the service side, there is no way possible you can eliminate any possible future failures on a 10 year old car with 220k miles. No matter what services are performed, failures will come. So I don't think you are being realistic with what your expectations were suppose to be after all the services the dealership performed. These cars are not bulletproof, that's a term tossed around way too loosely.
    Regarding your Hybrid Pit comment, the car I purchased with 200k miles was serviced exclusively by Hybrid Pit. However they did something very strange that I cannot explain and they cannot really explain either. There is no paperwork on a replacement water pump yet when I went to replace the pump, the pump had a date written on there 10/12/2022, which is the date of the last major service performed there. I find it odd they would write a date on a water pump and not replace it. I had emailed them numerous times but got no response. I ultimately contacted the previous owner to contact them directly and then they responded to him that they didn't think the pump was replaced and the tech that worked on the car no longer works there. So with no real proof, I replaced the pump myself again, even with that date on the pump.
    But going back to the major service of 10/12/2022, that service included most of everything you did at the Toyota dealership. All the fuids, plugs, intake/EGR cleaning, etc. So with that in mind you would think the car would be perfect? Well the answer is NO. I bought the car with a slight rattle, like the beginning of a head gasket failure sound. So basically what you're going through and my car at 200k did the exact same thing.
    #25 JC91006, Jan 13, 2024
  6. Mendel Leisk
    41,488
    For oil check: pull the dipstick, wait 5 minutes (check tire pressures or something). This gives oil drawn up the dipstick tube (by the dipstick being pulled) time to drain back down. Reinsert and withdraw dipstick, hold horizontal in a good light, angled to bounce the light. Should help. The face of the dipstick towards front of car tends to be least "ambiguous".
    Hino and John321 like this.
  7. mikefocke
    4,005
    1,808
    Sanford, NC
    I roll the dipstick onto a paper towel where the oil/no oil line is more clearly visible.
    Hino, John321 and Mendel Leisk like this.
  8. Hino
    Hino New Member
    Ridgedale, MO.
    The vehicle being 10 years old with 220,000 miles and zero service records showing any fluid changes; I thought changing them out would be a prudent and safe thing to do for the life of the vehicle. I don't believe that as a Toyota Service Advisor that if you suggest to your customers to continue to drive their vehicles after they tell you that you've got a CEL will end well for that Advisor or Dealership. Additionally, the dealership not having approval to begin to handle my new engine and install it for the price I stated that I was willing to pay .. how can that end well for the dealership? I have all this in texts to the Service Advisor.
  9. Hino
    Hino New Member
    Ridgedale, MO.
    This sounds like great advice. After the first hour after shutting the car down, I checked the oil at least 10 times over the next hour and a half. Each time the oil on the stick was way up at the crimped area of the dipstick. The dealership checked it as well and again, the oil was well over the full dot at the crimped area of the dipstick. The mechanic that did the oil and coolant which was up by the overflow tube exclaimed: Well, that's not like really high. I thought, yeah it is and you might be too. I have to believe that the Factory Engineers that designed the engine have a very good reason for placing high and low marks on the dipstick and fluid reservoirs for a reason so the vehicle isn't damaged as a result of over filling or under filling. Otherwise why mark the dipstick and reservoirs at all ? I'm not sure what this guy was thinking. Just do it right.
  10. Hino
    Hino New Member
    Ridgedale, MO.
    I asked my Service Advisor why he didn't inspect the EGR System when they were doing their de-carbon service and fuel system service and he told me that " There is not a Toyota approved way to clean the EGR and cooler." However as an Advisor that has access to Toyota information about the sticky EGR, you should recommend removing it, inspecting it and replacing it if needed. The Advisor stated that he didn't agree with me. He told me that Toyota states that it takes THREE HOURS to remove it at $180 per hour. This thing isn't hard to get to and yes, there's mounting bolts going multiple directions but that still seems really excessive. But he's got one job to do as a Service Advisor and that is to Advise Toyota customers in full and in a ethical way.
    I'm hoping that with my new engine with the revised pistons and piston rings, brand new EGR System, new water pump, new fuel rail and fuel injectors, new PVC, new fuel sensors, new oil control sensors and other sensors in addition to the brand new revised intake manifold along with proper timely maintenance I'm hoping for at least another 220,000 miles.
  11. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Hi Hino
    Interesting, intense story.
    Here is my 2c worth.
    Sell this Prius. You will likely recoup a large portion of your costs.
    Buy a new car. Keep the new car only until it is out of "all inclusive" warranty. Then sell it, and but another new one.
    A wise friend, who did not ever want car problems, did this. Its not cheap but given all that car owners are up against, it is the most reliable way to deal with transportation. Used cars are not the way to go - as you have just learned. Also get all the insurance you can, from a company that is highly rated for actually paying claims. .Life is too short, and complicated, to fool with used cars. Good luck. ,
  12. rjparker
    rjparker Tu Humilde Sirviente
    10,163
    6,317
    Texas Hill Country
    Hino
    You bought a high mile gen3 that almost certainly ALREADY had a blown head gasket. Scammers add head gasket sealer to the coolant and it will then run fine for several months. Until the head gasket fails again.
    With the sealer working, no “inspection” by the dealer could have detected the compromised head gasket. Not a borescope, not a leak down test, not a combustion gas analyzer.
    The guy who sold it is the scammer, not the dealer.
    Give a dealer a blank check and they will do exactly what you ask. Absolutely none of it would have diagnosed or prevented a head gasket failure.
    No chemical decarbon process works, especially in a gen3.
    Cleaning the egr would not fix the head gasket or even prevent it.
    Getting a new Hybrid Pit engine was a good move and now the engine will be fine for another 200k miles.
    Your next surprise will be a $2500 master cylinder.
    #32 rjparker, Jan 14, 2024
  13. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    You've already received good advice from others regarding your main situation, so I'll just add this:
    Dealers selling used cars do not preserve any sort of maintenance records from one owner to the next. This is intentional- they don't want the risk of accidentally sharing the prior owner's personal information.
    That's one of the big advantages of buying a car direct from a private party seller: you get the records.
    Conversely it's one of the big advantages of dumping a problem car in a dealer trade-in: the next owner will never find you.
  14. vvillovv
    4,321
    1,510
    NY
    What was the reason given for the CEL being on? That is the one thing I would have ask to have checked and fixed first. Well I'd have also asked for the oil change too if it was over filled like mentioned above.
    That way you can check things out and evaluate the cars condition for those services first. Than again, now we read you've decided on an engine replacement, complete with intake manifold. new egr system, injectors, sensors, and all fluids changed (whatever that means to you and or the maintenance dept, if they are different in the smallest detail). Now I wondering what the how much you paid the dealer and how much and of what part of the final bill(s) are being disputed.
  15. Mendel Leisk
    41,488
    How about just trickle out a cup or so at the drain bolt. You back out the drain bolt till it's almost out, then a wee bit more, while keeping pressure on it, then cant it slightly to get a trickle going. Seems a waste to drain and replace all that oil cus of a cup or so overfill.
    I did that after the last dealership oil change I ever got, with a previous car. Spec said 3.2 liters, and dealership routinely slammed in 4.0.
    Hino likes this.
  16. rjparker
    10,163
    6,317
    Texas Hill Country
    I have a manual pump up fluid extractor that easily sucks out oil through the dipstick tube. Comes in handy for overfills, oil analysis samples, mowers, generators and even early mid cycle vehicle oil changes.
    I would be interested in how much the dealer charged to install the Hybrid Pit rebuilt engine.
  17. vvillovv
    4,321
    1,510
    NY
    I have a similar story about the ( first ( and almost ever other dealer oil change ) being half to a quart over )), on our brand new, 2 or 3 mount old 2002 Honda Civic EX. - After 30 mpg hwy on a trip from NY to FL I got it (the oil ) changed in Hialeah at a speed shop and got the cars typical 40 mpg hwy on the trip back to NY.
    Some might remember me posting about this previously here.
    Hino likes this.
  18. ETC(SS)
    7,172
    Sometimes?
    "Free" isn't worth it.
    Think about that the next time you're offered the chance to be victimized by your local dealer, and remember.....
    If the product is 'free'?
    YOU are the product.
  19. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    I quite agree with this part.
    Hino likes this.
  20. Hino
    Hino New Member
    Ridgedale, MO.
    Hello John. Thank you for your advice and good wishes. This story I think is a cautionary one that others can learn from when receiving poor advice or taking their vehicles to the pirateship/stealership.. especially for younger consumers, elderly consumers or consumers that are dealing with heavy personal situations like dealing with the death of a parent. We should be able to trust our Toyota dealerships not to take advantage of us, especially those I've mentioned. I have a 2003 MR-2 Spyder that I haven't had to do anything to besides fluids and a battery. Purchased it for cash in 2003 so this used vehicle has saved me a mountain of cash in contrast to buying a new car every four years for the last 21 years. Toyota produced it with a modified Corolla engine and it's been bulletproof. I also have a 2010 FJ Cruiser which I purchased about 10 years ago. Again, only fluids but also spark plugs. Hino produced this truck for Toyota. A very well made truck except for the junk metal that was used in it's frame which was supplied by Kobe Steel. Kobe Steel reimbursed many of it's corporate customers across many industries but evidently not Toyota as nothing has been documented. Two vehicles that have probably saved me about $100K with combined ownership years of 31 years. There's no pre-determined rate at which a vehicle will depreciate. However, within the first year, many cars will lose up to 20% of their value. After that, they may lose about 15% more per year until the four-or five-year mark.
    With the average cost of a new vehicle in the US at nearly $50K, can you imagine losing $25K over and over and over again vs. keeping my other two vehicles for 31 years of combined ownership? Doing fast math, roughly $200K savings not even counting higher insurance and personal property taxes. So, it's not so much that used cars are the issue, rather it's getting used and taken advantage of at the stealership is... and yes, if I wasn't caring for my mom, I would have read up on the third generation Prius.. but I really failed when I trusted my Service Advisor.
    Maintenance records, Service records, accident records, registration records, ownership changes and salvage title or other title information are all things that are available, typically, when you get a Carfax or AutoCheck Report. (The majority of dealerships big and small will actually provide one of the reports free of charge.) All this information is loaded in databases and shared. If the used vehicle that you're purchasing was exclusively serviced at Toyota Dealerships, you tend to get even more information. So that information is out there. Go to Carfax and purchase a Report for one of the vehicles that you own and you can see what I'm talking about. Ironically, tucked in with the owners manual for my 2013 Prius was a receipt that contained the previous owners name, address, phone number and email. It was a one owner vehicle and the owner lived in a very remote part of Arkansas not near any Toyota Dealerships so he had a local mechanic at a small garage doing his maintenance. Probably using 1970's style paper receipts without a computer. That's most likely the reason that only his purchase date, dealership information and registration information hit any database when I purchased a Carfax for this vehicle.
    BUYING A CAR FROM A PRIVATE PARTY..Very few owners including myself have all my paper copies of all my receipts and service/maintenance records. Some private owners won't provide them especially if they're trying to hide something like multiple accidents or a branded title for examples. People are people and not all are honest whether they work at a organized racket like a dealership or selling individually.
    RJPARKER;
    It's difficult to know if this Prius "almost certainly ALREADY had a blown head gasket. "
    How many Gen 3 owners are on this platform? 200? 500? Have 'almost all' Gen 3 Prius owners with 220k miles suffered head gasket failure? 100%? If that's the case, your answer is valid. Also if that's the case then there is a root cause. What is that root cause? Let's say that no inspection or signs of a head gasket failure are able to be seen or detected. I'd be inclined to think that a good, experienced mechanic might have something to say here. So, the dealership gives me a false sense of security and say that they've checked the car out throughly and she's in fine running order and additionally misleads me by not sharing information that Toyota shared with them about the issues with this car through TSB's, Enhanced Warranty Letters, part and service campaigns, etc. Setting me up for future failure and dealership profits $$$. Is this what a Service ADVISOR should be doing? If his motive is enriching his paycheck and dealership profit, I'd say he's self-serving and doing a great job of it. If he's not really a Service ADVISOR then re-title these people. We can vote for titles. Lol. The dealership that sold me the car may (or may not) be a scammer as you insist my focus here is about the folly of the dealership and the harm that they caused. I do absolutely agree with you that the roughly $400 I was charged for the snake oil de-carbon service was an absolute scam. Especially when I saw how filthy the old engine was internally after it was removed. I don't think that fraud like this should go on like this at a Toyota dealership. Has any other unfortunate soul here been scammed in this manner with the expensive de-carbon service?
    The dealer wasn't giving a blank check and what I asked for was fluids, spark plugs and a complete inspection and advice to keep this car healthy. It was the dealer that suggested this crock of a two-step de-carbon as a false sense of security and the process failed as revealed post mortem examination. The Service Advisor had one job to do and he failed me.
    #40 Hino, Jan 17, 2024
