Pour one out for my 2009 boys :(
Discussion in 'Gen 2 Prius Main Forum' started by T.S. Elliot, Jul 3, 2026.
  1. T.S. Elliot
    T.S. Elliot Member
    84
    25
    Desolation Row (MN)
    I rear ended someone with my 2009. Ironically I bought this car from Copart with front end damage in the exact same location, but at first glance this looks way worse than what I can repair. I am going to tear into it now. Any thoughts? It's already leaking some coolant and the thermos pump sounds unwell. Can't tell if the A/C condenser is still holding Freon or not based off initial impression as was only running the car very briefly to get it on to the dolly and then into the garage.
    This is devastating. The car has 203k. It has the following new OEM Toyota parts installed at 155k (warning - this will be painful): A/C Condenser, radiator, mechanical water pump, serpentine belt, idler pulley w/ bearing, inverter pump, 3 way valve, and thermostat. The stealership has changed the brake fluid and charged the A/C. The worst part? The coolant and CVT fluid were both changed at 200k and it has a full tank of gas.
    p.s. just thought about how my set of FIAMM freeway blasters fared :(:cry:
  2. T.S. Elliot
    T.S. Elliot Member
    84
    25
    Desolation Row (MN)
    Update: I'm going to need help with this one. I managed to get the hood open. There's a tiny chance the condenser and rad can be saved. The bad news is that the inverter took the brunt of the hit and the coolant leak appears to be isolated to the inverter loop, perhaps the inverter itself. I have yet to identify the source of the leak, but the reservoir was empty. The highest place I have found coolant is on the aluminum tube running underneath the coolant reservoir. Next step I am going to remove the inverter. I have never done this before. I hope that by doing this I will identify and pinpoint the actual source of the leak. Not sure what I'm going to find, but I am worried about something like a metal coolant nipple being broken. I have 2 spare inverters on hand so in theory I could do a swap if the damage was isolated to the inverter itself. Although I don't know the condition of either, I guess trying beats having a bricked car.
    p.s. the freeway blasters were spared thank god :DMostly because the damn bumper on these cars always misses and never does a thing!:mad:
  3. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Sounds like a pretty quick fix actually that's all that took the hit great .
    T.S. Elliot likes this.
  4. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    Need more pictures.
    From what I see it isn't clear why the inverter loop would bleed out, unless the top of that bent radiator support and the front of the hood are pushed back all the way into the inverter. Or maybe the radiator rotated enough to tear out one or both of the inverter hoses? It does look like it is tilted back.
  5. T.S. Elliot
    T.S. Elliot Member
    84
    25
    Desolation Row (MN)
    Thanks guys. I have basically a full damage assessment now. The leak around the inverter was due to the fact that the reservoir was in 2 pieces. Swap from spare and easy fix. Unfortunately that will be the last of the easy fixes. The rad is confirmed to leak and the fan shroud is also junk so will have to pull everything. I will have to redo the metal in order to accommodate 100% functionality of the inverter mounts, hood latch, rad/condenser mounts, hoses, etc. Looking at pulling fender as driver door currently barely opens. Won't be a fun job, but just on me to figure it out and get it done.
    My question is about the A/C system and the results of my test. I tested it and the a/c compressor didn't sound smooth at all. It would spool up hard for a couple of seconds and then just stop. After just a couple times of hearing that I aborted the test and the condenser was super hot. I initially thought about trying to save the condenser, but this scares me. Do you think somehow the compressor could've received damage too? What you see on the front of the condenser is actually coolant from the rad. I haven't seen any evidence of leaks from the condenser yet but I think it may be bad.
    #5 T.S. Elliot, Jul 5, 2026
  6. pasadena_commut
    3,071
    956
    Southern California
    I wouldn't run the A/C until the status of the refrigerant in it is determined. If that has leaked out running the compressor would be a bad idea. Might also be a bad idea if anything broke off inside the condenser as a result of the crash. That said, if you ran the compressor and there was no fan then I assume the condenser should become quite hot normally. The compressor increases the pressure in the refrigerant which raises its temperature. (Same reason a bike pump gets hot in use.) Normally that heat is then removed by air moving through the condenser, but if there is no such flow, it could only escape slowly through secondary mechanisms.
    How did the inverter reservoir break when there isn't even a ding in the inverter cover?
    Is the fuse box sitting at the normal angle? In some of the pictures it looks like the cover might be tilted up, but maybe it was just open.
    I have seen a lot of wrecked Prius in the junkyard, but never one as intact as this one is from the top of the tire on down. The wheel well liner is intact (a very rare thing), the thermos bottle is pristine, and the frame going out to where the bumper mounts looks perfectly straight. All good signs.
    Obviously it needs a fender and headlight.
    The bent pieces around the radiator should be in this diagram:
    https://www.amayama.com/en/genuine-catalogs/epc/toyota-usa/prius/NHW20L/8936/body/5304
    The black support piece from the inverter to near the radiator looks bent. I could not figure out what that part is, it does not seem to be in the preceding diagram or the inverter diagram:
    https://www.amayama.com/en/genuine-catalogs/epc/toyota-usa/prius/NHW20L/8936/electric/8431
