Power behind rear seat cup holder?
Discussion in 'Gen 2 Prius Technical Discussion' started by frevnew, Oct 21, 2020.
  1. frevnew
    frevnew New Member
    Conroe, Texas
    Does anyone know what this plug goes to? It shows 13.83 volts when car is ready. Would like to tap it for rear USB ports in my 2009.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    IF.....there is no 12 V socket nearby, my guess would be a "courtesy light", maybe inside the armrest glove box.
    I assume that you can't see where the wires are going ?
  3. frevnew
    frevnew New Member
    Conroe, Texas
    Nope. Saw in a post somewhere someone said there is an oscillator in the arm rest? No idea what that is for.
  4. sam spade 2
    7,035
    2,804
    2017 Prius c
    Not likely.
    The only way that would be true is if there is a 120 VAC outlet on or in the armrest.
    The "oscillator" would be an inverter.
  5. ChapmanF
    19,025
    'Oscillator' is what Toyota calls their smart-key system transponders, of which there are several, located various places in the car. One is beneath the center console, as I recall.
  6. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    The oscillator sits vertically at the rear of the console in front of the cupholders.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    If this really is a part of the key transponder system, you probably should NOT tap into the power wire that runs it.
