Power button light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MM Butler, Dec 11, 2025.
  1. MM Butler
    MM Butler New Member
    Revere, MA
    Could have sworn that the power button light should be green! The other day it was red, car started up fine and drove. Someone told me to replace the battery in the key fob. I did. Now the light is amber! I start the car with foot on brake, press the power button, light is amber then goes out. Ready light is on dashboard, car drives. Looked at some online info - could be 12v battery, could be hybrid, it also could be fine!! 12v was checked - 12.02 before starting car. 14.2 when started. Need to know if it's a big deal because it does run.
  2. Tombukt2
    Tombukt2 Senior Member
    13,672
    2,477
    Durham NC
    12 .2 is starting to take a dump .car is smart
  3. dolj
    dolj Senior Member
    8,614
    4,373
    Wellington, New Zealand
    No, it isn't, 12.02V is a long way off the 10.5V mentioned in the repair manual, and it really depends on the actual fault that is reported to know if voltage is a factor.
  4. MM Butler
    Revere, MA
    Got a new battery. Amber light came on power button and went out. Ready light is on dashboard. Car drives.
    I read that 12.2 was low for battery with no load. Replaced battery. Amber light came on when pressing button. Went out. Ready light on dashboard. Car started and drove.
    #4 MM Butler, Dec 12, 2025
  5. Hayslayer
    Hayslayer Active Member
    495
    286
    Indicator
    Power Switch B080592E01
    Power Switch Mode Indicator Status
    OFF OFF
    ON (ACC) Green illumination
    ON (IG) Amber illumination
    Hybrid System ON OFF
    Push button start system malfunctioning Flashes continuously in amber
    Tombukt2 and Brian1954 like this.
  6. MM Butler
    Revere, MA
    I always thought the light on power button was green? Doing some internet searches and it's saying it shouldn't be amber. So you're saying that amber is ok?
  7. Tombukt2
    13,672
    2,477
    Durham NC
    Check your 12 volt 30 minutes after you shut the car off with dvom at batt if possible or at jump point if ya must
  8. Hayslayer
    495
    286
    Just showing what the repair manual chart shows for normal operation:
    If the power switch is OFF, the indicator is OFF
    If the car is in ACC mode, the indicator is Green (one press of power button with foot NOT on brake)
    If the car is in IG-ON mode, the indicator is Amber (two presses of power button with foot NOT on brake)
    If the Hybrid system is ON, the indicator is OFF (one press of power button with foot ON brake)
    If the push button start system is malfunctioning, the indicator will flash amber continuously.
