Power button ready condition
Discussion in 'Gen 3 Prius Technical Discussion' started by jbcarey, Nov 12, 2012.
  1. jbcarey
    jbcarey Junior Member
    45
    Poughquag, NY
    2011 Prius with 30,000
    October 30, 2012
    at the first start of day when I pressed on brake pedal and got the green light on power button as usual I pressed power button and never got ready condition, trying to figure out what is happening I have had this condition occur almost every morning (outside air temp around 40 degrees F
    also when I went to train station to pick up my daughter I shut off for about ten minutes and it happened again.
    can anyone shed any light on this subject
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Low 12 volt battery? Low key fob battery? Interference between key fob and car? Bad brake light switch?
    What if you hold the fob up to the power button trying to start the car?
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I'd guess a faulty brake light switch or you're not pressing the brake pedal hard enough.
    I've done it where I pressed the power button a fraction of a second before I had my foot fully down on the brake pedal.
    Now I usually press the brake pedal and wait until the ABS pump stops whirring (2-3 seconds at most) before I press the power button.
  4. jbcarey
    45
    Poughquag, NY
    Thank you percy, I will try that and see what happens, I have been doing this for a year now and just noticed this condition, but I will focus on the brake application to continue my investigation
    Jeff
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
