Power button unresponsive in hot weather
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DrowningInteger, Jun 23, 2025.
  1. DrowningInteger
    DrowningInteger New Member
    22
    Arlington WA
    Howdy y'all. I have a 2006 Prius with 143k miles, and it doesn't want to start in hot weather. I see the door light on the dash but nothing else comes on when I push the power button. No instrument cluster, no MFD, no noises. Is there a good place to start for troubleshooting? The hybrid battery and 12v battery are less than a year old. The 12v battery is currently showing 12.3v on my multimeter. Disconnecting the 12v battery for a few minutes will allow the car to start after hooking it back up.
  2. Tombukt2
    Tombukt2 Senior Member
    13,700
    2,480
    Durham NC
    And when the car starts after hooking up the battery then do you have displays speed trans and gas,?????
  3. DrowningInteger
    22
    Arlington WA
    Yes, when it's working everything comes on and functions normally.
  4. JC91006
    16,893
    8,627
    You probably have a problem with your combination meter. The dash lights not turning on.
    Brian1954 and Tombukt2 like this.
  5. DrowningInteger
    22
    Arlington WA
    That's what I thought too, but I didn't think the combo meter prevented the car from starting and driving.
  6. JC91006
    16,893
    8,627
    I think your car started, just you couldn't see any dash lights. You can try and press the start button and wait 10 seconds, see if the car turns on.
  7. DrowningInteger
    22
    Arlington WA
    It didn't though. I couldn't shift and it wouldn't move. Plus the MFD wasn't on either. I took a look at the negative battery cable and it doesn't look like the right size for the battery, it just has some shims jammed in the connector. I'm going to try to find the right battery cable and see what that does.
  8. Tombukt2
    13,700
    2,480
    Durham NC
    It doesn't . Sometimes to start hold button till ya see check lite let go of button and drive.
  9. JC91006
    16,893
    8,627
    if he can't see his fuel level, he might be out of gas
    Tombukt2 likes this.
  10. DrowningInteger
    22
    Arlington WA
    Fuel level was above half the last time it was driven.
  11. Tombukt2
    13,700
    2,480
    Durham NC
    I think it'll turn on. Just ice can start then off I gues or it'll spin .
  12. JC91006
    16,893
    8,627
    I would add 3 gallons of gas in it and try again. Most no start issues with bad combination meters end up as out of gas situations.
  13. DrowningInteger
    22
    Arlington WA
    I fiddled with all the cables attached to the 12v battery until I was reasonably certain all of them were making a good connection and it started up again even though the weather was about the same as it was yesterday. I'm cautiously optimistic that was the only issue. But I guess I'll see over the next week or so since sometimes it works and sometimes it doesn't.
  14. DrowningInteger
    22
    Arlington WA
    Nevermind it wouldn't turn on again today. It worked fine for about a week after an hour drive and then it sat for about a week so I'm wondering if it just needs to be taken on longer drives more often. I charged up the 12v battery with jumper cables and that didn't do anything. The immobilizer light comes on when I push the start button and the key is too far away, and the door open light is on when the door is open, but those are the only two lights that will show on the dash. I don't hear any beeping when the door is open, but it does beep when the headlights are on and the door is open.
  15. JC91006
    16,893
    8,627
    I guess it's time to test the 12v and possibly get a new one.
    Brian1954 likes this.
  16. DrowningInteger
    22
    Arlington WA
    Yeah I was thinking about getting a new Toyota battery and a new negative cable. I just wasn't sure because the battery in it now is an Optima that's only a few months old. I found another thread on here where someone had the same problem and they had a loose connector in the wiring behind the dash so I'm going to poke around in there first before I drop a couple hundo on a new battery.
  17. DrowningInteger
    22
    Arlington WA
    Although the battery measured at 12.8v after I charged it and still nothing came on so I feel like there has to be a wiring issue somewhere. I guess there's a chance the battery could still be defective.
  18. JC91006
    16,893
    8,627
    If your headlights turn on nice and bright, then it shouldn't be a problem with your battery.
    It may be you have a stored code that only allows your car to start once. So disconnect the battery and start the car. If it starts, shut down and see if it'll start again. If it does not, then you have a P0AA6 code that you just can't retrieve, but it's there
  19. DrowningInteger
    22
    Arlington WA
    That's the annoying part. Sometimes it will start multiple days in a row without an issue. And sometimes it just won't start even after disconnecting the battery. The headlights work fine.
  20. JC91006
    16,893
    8,627
    have you tried using the key slot? maybe the sks function or the battery in your key fob is not working well.
