Power door customisation
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Nakamoto, Feb 21, 2014.
  1. Nakamoto
    Nakamoto Junior Member
    69
    Melbourne
    Hey Guys,
    What sort of tools do I need to customise settings for door lock?
    I want to have this function turn ON:
    • Function that locks all doors when the shift lever is moved from P to any position other than P while the engine is running and all doors are closed.
    Gen III Prius - Customizable Parameters
    thanks!
  2. FrankB
    FrankB Member
    117
    53
    Bluetooth ODB2 adapter
    Carista beta
    That's probably the easiest way doing it yourself.
    Frank
  3. bathala
    bathala Member
    128
    30
    Area 52
  4. FrankB
    FrankB Member
    117
    53
  5. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Can more than one function be active at a time? Or is it one or the other?
    I want the doors to lock and unlock based on the P(ark) selector position. However, I also want the doors to automatically lock based on the speed of the vehicle, such as dropping off a child at school. The car is pulled up to the curb, selector is left in D with brakes applied, car is unlocked with armrest power lock master switch, or by opening door. Pull away from curb without manually locking the doors with master switch.
  6. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi Nakamoto,
    The customizable parameters are for US Prius and may not be applicable to your Australian Prius. Please check your Owner's manual first. If yours is not equipped with this feature, no tools can enable them, not even Techstream.
    Vincent
  7. bathala
    bathala Member
    128
    30
    Area 52
    It's possible to have both but I haven't tried. When I purchased my car, it's default to lock when the shifter is on D and unlock when it's on P.
  8. Nakamoto
    69
    Melbourne
    OMG it works! thanks for the manual
    bathala likes this.
