Power Green Light and Brake lights not working
Discussion in 'Gen 3 Prius Technical Discussion' started by Ghulam Ali, Apr 7, 2021.
  1. Ghulam Ali
    Ghulam Ali New Member
    London
    Active
    Got a problem with my prius 2014.
    When I press brake pedal No green light on Start Switch. Brake lights also don't light up when I press brake pedal.
    Plz help
    52,804
    sounds like the switch on the brake pedal needs adjustment. try pressing the pedal harder first.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    What bisco said.
    If the brake switch is bad or the fuse is blown then it won't ready up.
  4. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    Have you checked the 12V battery?
    Grit likes this.
