Power Inverter Converter Failure
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Don Dannelley, Jul 28, 2020.
  1. Don Dannelley
    Don Dannelley New Member
    Wichita Falls TX
    My Power Inverter Converter has failed error code 3004, took to Toyota Dealership, If i decide to change myself is there any programming that needs to be done or just a straight swap out?
  2. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    What mileage? Did you ever did an inverter coolant change?
  3. PriusCamper
    PriusCamper Senior Member
    13,187
    5,335
    Pacific Northwest, USA
    In Gen2 Prius you usually replace the inverter cooling pump due to history of them going bad, but not sure if that is an issue with Prius C?
  4. Don Dannelley
    Wichita Falls TX
    The car has 132,000 and no I did not know about the coolant change, newbie with HV cars.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Can you provide us with a few more details about the dealership diagnosis? The P3004 has a few subcodes on a Gen 2 to help determine problem source. I would imagine it's similar for a 2013 C. Maybe a photo of the dealership diagnostic paperwork?. I would be hesitant to immediately jump into an inverter replacement.
    PriusCamper likes this.
  6. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Any updates on this?
