Power locks malfunctioning
Discussion in 'Gen 3 Prius Technical Discussion' started by DrTrivia, Jan 30, 2017.
  1. DrTrivia
    DrTrivia Member
    44
    27
    Started having this issue with my 2011 Prius III. The driver door stopped locking/unlocking with the keyfob. I can still be manually unlocked with the key, and from the inside with the lock switch. It is not affected by the lock/unlock buttons on the driveside door. The problem is not intermittent, it just stopped working. A little while after that, something similar started happening with the front passenger side door. The keyfob will (sometimes) lock that door, but cannot unlock it. That lock is also unaffected by the driverside door lock/unlock buttons. This problem was intermittent at first, but then became constant. I'm finally getting around to opening up the doors next weekend, but it would save me a lot of time if I had some idea of what to look for beforehand.
    In previous cars I've had this issue with I've had problems with broken cables that lead to the electric actuator. Not sure if the prius is similar, since my repair manual does not have a diagram of the inside of the doors. Any suggestions would be appreciated.
  2. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    Had this happen on my passenger door. Replaced the lock actuator with the help of a friend who is good at car repair. It's a fairly big part that contains both the actual locking mechanism for the door and the actuator motor. We disconnected the cables that go to the switch from the old one and reconnected them to the new one. He said it was pretty easy, although not being mechanical it didn't seem as easy to me. Ordered a refurbished one on eBay for about $45, with lifetime warranty if I send back the old one (probably so the seller can refurbish it too). Fixed the problem, and saved hundreds since mechanics want $350 or so for a new part. Good luck!
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Do a search on here for "actuator".
    Common failure.
    52,858
    could be your fob battery or 12 volt battery. are you saying the actuators work from the inside electric door switch?
  5. DrTrivia
    DrTrivia Member
    44
    27
    Thanks for the replies. It was bad actuators. Don't know why, when I searched the forum, I looked for "power locks" instead of "actuators" since I should have checked both. I got two new ones on eBay (thank you Kramah313) for a decent price. Removal and installation were very easy and everything works just fine now.
    Kramah313 likes this.
