Power mode?
Discussion in 'Prius c Main Forum' started by eddie27970, May 17, 2017.
  1. eddie27970
    eddie27970 Junior Member
    56
    Eastern North Carolina
    Have had my Prius model C, package 4, over a year. (my 7th Prius) all others have Power switch. And this model C also seemed to have a Power Mode. But then it stopped the boost feeling. Just recently found out what gives a big burst of power. Put it into EVmode. Feel the power boost to car. Compare to EV off and then on. Love the power boost.
  2. InPriusLove
    InPriusLove Member
    167
    42
    California, US
    2015 Prius c
    In Eco Score screen, you can view power mode on the arch. But in my experience the EV mode is never available (console push-button) in actual speed driving. Yet EV mode spontaneously operates in higher speeds and the EV alone will not give that kind of push. I do not know how your car is doing that. On the other hand, the B gear is a hot-roddy kind of thing if you gun it. It will push the engine like a 1st gear and normalize at traffic speeds. Eco mode does similar but with higher challenge. I do not like the drag of Eco Mode. If you quickly and fully depress the accelerator hard in standard mode the power mode is activated.
  3. rjdriver
    rjdriver Active Member
    410
    170
    Rhode Island
    Power mode? I have a 2012. Do the newer models have a power mode? Never heard of that with a C.
  4. InPriusLove
    InPriusLove Member
    167
    42
    California, US
    2015 Prius c
    The only power mode I know of is based on the Eco Score arch. It isn't a tachometer. This arch on this display screen has sensitive movement gauging the power levels from EV (where you see an LED light when EV mode is working) to Power, the far right side red shaded area. It is not the same as a tach redline. The CVT equalizes on this plain when fully engaged. It provides the short term power burst and sustainability during a time of need. I consider this to be the closest C equivalent to a standard Prius Power mode that could be available.
