Power Outage During Charging
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Sep 23, 2017.
  1. stevepea
    stevepea Senior Member
    535
    581
    Has anyone experienced a power outage yet (due to the local power co) while charging their Prime?
    If so, I'd be curious what happens. When charging the Prime, if the power suddenly stops, once it comes back on will the Prime continue to charge, or stop?
    Here in SoCal (SCE), in my tract, we get brief power outages maybe every 2 months or so (not due to weather or high load) -- and the entire tract gets it, not just me. Power usually comes back on within 30 seconds, but clocks without battery backup capability always start blinking and need resetting.
    So I'm sure at some point a power outage will happen while I'm charging the Prime. Obviously outages (and then the power going back on) aren't a good thing, but what can I expect to happen?
    #1 stevepea, Sep 23, 2017
  2. krushmoto
    krushmoto Member
    65
    44
    US
    I've unplugged my charger from the wall to move the cable then plugged it back in and it goes right back to charging. Shouldn't be any different.
    I've noticed that it doesn't charge immediately upon plugging in. I think the chip(s) analyse the batteries voltage etc before it starts charging.
    Nexus 6P ?
    HPrimeAdvanced and stevepea like this.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Why are outages obviously not a good thing? What makes brown outs on a laptop, your cell phone, a clock with battery backup any different than a plug in car?
    priuscatprimeguy likes this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    The difference being: one does not have a HV battery backup for the car.
    HPrimeAdvanced likes this.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The only issue is, if you have a charging schedule set and you're charging outside of it using "Charge Now", it probably won't re-start charging.
  6. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    I would unplug it and wait for power to come back on. I would not want a power surge like you get sometimes.
  7. Andyprius1
    2,327
    859
    Cool CA
    Stay home, don’t go to work!
    HPrimeAdvanced and huskers like this.
  8. huskers
    2,548
    2,488
    Nebraska
    Yes, we will write you a note.
  9. huskers
    2,548
    2,488
    Nebraska
    I had a student who brought me a note once. It said, "Please excuse Dennis. He had to go to the doctor with his ears".
  10. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Our power is very reliable, but we did have a 30-second interruption a few days ago. Probably due some maintenance work being done by the local utility.
    The only thing that happened is that I received a notice from Entune:
    Date: Mon, 12 Feb 2018 02:37:21 +0000 (UTC)
    Subject: Charge Notification - Charge Interruption Notification
    Dear Bear,
    Our systems indicate that your Bear-Mobile vehicle's charging process was interrupted.
    If you have any questions or you feel you received this email in error, please contact the Toyota Customer Experience Center at 1-800-331-4331.
    To opt out of receiving Charge Notifications in the future, please visit http://www.myentune.com.
    Best Regards,
    Toyota Entune Customer Support
    This is an automated message, please do not reply.
    The charging process resumed when the power was restored and I later received the normal and usual charge completion notification.
    I am using a Leviton EVR-40 which is a basic EVSE charging unit. If your EVSE has network-enabled or other special features requiring a manual restart, your results may vary. That is, it's up to your EVSE to come back to life. When the Prime senses the power has been restored, it will just take up where it left off.
    One other comment: If you have your Prime set up on a charging schedule to allow enough time to be fully charged by some scheduled departure time, obviously it won't be able do this if there is no power during the hours which it's scheduled to be charging.
  11. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    also if your scheduled charging has commenced and the power goes out you will have to manually charge now or else it will not continue charging when power is restored.
