Power Outlet Relay?
Discussion in 'Gen 2 Prius Technical Discussion' started by tkc100, May 1, 2026.
  1. tkc100
    tkc100 Member
    92
    25
    Arizona
    Has anyone had the need to locate the power outlet relay? See the attached PDF. I can see from the diagram just about where it's at, but whether or not it is accessible without tearing the dash apart, I can't tell. Any advice would be greatly appreciated
  2. BiomedO1
    BiomedO1 Senior Member
    4,636
    2,434
    Left Coast
    If it's too tough to get to; I'd probably just run another line - rather than ripping the dashboard out. Don't forget to place a fuse on the new line.
    Just my 2 cents.....
  3. ChapmanF
    19,053
    From the drawing, it looks fairly accessible after taking the dash top off, if it comes to that.
    Taking the top off is a bit tedious, but a lot less so than tackling the whole dash.
  4. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Dash top must be off the two light blue relays 82827 is series of numbers on one of em .you can't unplug the relay with dash top in place . The part needs to lift up towards windscreen to remove . Looking at it now .have pics .
  5. tkc100
    tkc100 Member
    92
    25
    Arizona
    Thank you all for getting back to me so quickly.
    I guess I was hoping against hope.
    From what I could see it looked like it wasn't going to be just a simple task, but it couldn't hurt to ask. It would be terrible to take the top of the dash off only to find out that there was a very simple way to access the relay.
    I've had the top of the dash off previously when I had to change that little capacitor on the back of the instrument cluster.
  6. Tombukt2
    13,875
    2,521
    Durham NC
    Yes that instrument cluster time would have been ideal because it's sitting right there can't miss it . I cannot imagine what's wrong with.
  7. 6079smithw
    6079smithw Junior Member
    22
    N. Nevada
    Pulling that cover is time-consuming as anyone who has done it knows well. Just curious as to why you suspect
    the relay? Do all the other components check out OK? I had the little rivet that secures the positive contact inside
    the socket come loose from wear and cause an open; been my experience that type of relay rarely goes south.
    Like I said, just wonderin'...
  8. tkc100
    tkc100 Member
    92
    25
    Arizona
    The way it is configured both power outlets are accessory feeds. I needed a battery feed and had the relay had it been easily accessible it would have been easy to do so.
  9. ChapmanF
    19,053
    In both my earlier gen 1 and my current gen 3, I left both factory power outlets as they were, and just ➡added other circuits as needed⬅ at the battery, conveniently in a sheltered environment in the back of the car, as it is also in your gen 2.
