power steering rack bushings?
Discussion in 'Gen 3 Prius Technical Discussion' started by Szulkarn, Aug 10, 2018.
  1. Szulkarn
    Szulkarn Junior Member
    Indonesia
    hi there. i have a zvw30,
    my car makes clunking noise when going uneven road... annoying,..
    i changed my stabilizer link, balljoint and outer tie rod.
    the link is shot, the balljoint is loose and the tie rod is shot...
    but the clunking noise persist.. (lessen now)
    brought to the dealer, the mechanic immediatley, moves the steering wheel left and right, sure enough theres was a 'thud' sound when going left or right.
    he said needs to replace the whole steering rack.
    i know theres after market inner tie rod.. he just kept quiet..." no u need to replace the whole rack and pinion"
    then i asked again. how about bushings? i assume like most cars there are 4 pieces of bushing that hold the steering rack in place.
    he said "no bushings, need to replace the whole steering rack"
    frustrated , i was hoping he offered to lift the car and inspect it more carefully, but he didnt.
    so i was wondering
    are there any bushings that holds the steering rack in place?
    thanks all.
  2. worrachai
    worrachai Junior Member
    48
    thailand
    Please re-check the number 4 in below picture. I used to have the problem same as you. In 4, there are the steering grease inside. when the time was passed, grease has been lost out. Re-insert grease, I was done by toyota dealer in my country(Thailand). Cost is $20 included labor cost.
    If you don't need to pay anymore. please see in below youtube link.
    I hope this is useful with your problem.
  3. Szulkarn
    Indonesia
    wow. thank you for the reply. I hope this could be an easy fix. do you know ho to get access to the intermediate shaft? is it right underneath the steering wheel inside the cabin? or is it underneath the car?
    thank you.
  4. worrachai
    48
    thailand
    His location is underneath the steering, near by your right leg during drive.
  5. Szulkarn
    Indonesia
    Does opening the plastic trim straightforward as is ? Or i need to pop open the sides trims first?
  6. worrachai
    48
    thailand
    Open the plastic trim. you will see looklike the above youtube.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    You have a g2 car your posting in the wrong forum.
