Power Steering Screech
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by jerryberkowitz, May 7, 2014.
  1. jerryberkowitz
    jerryberkowitz Junior Member
    I am getting what sounds like my power steering belt screeching on my 2012 prius c Two on startup. I thought this model has no belts, so what may be the cause of this noise?
  2. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    About the only thing I can think of is the inverter coolant pump?
    SCH-I535
  3. jerryberkowitz
    Thank you for your idea. Is there an online diagram or picture of the pump and it's location? I am having an issue with my '06 prius where I am getting occasional p1150 dtc indicating stuck coolant control valve. I am wondering if this is the same problem. The only solution for the p1150 from the members here has been to add Barr's water pump lubrication to unstick the valve.
