Power Struggle?
Discussion in 'Prius v Technical Discussion' started by Shrug, Sep 29, 2022.
  1. Shrug
    Shrug Junior Member
    CA
    Hi guys,
    I am running a dash cam off the power outlet that would have been a cigarette lighter on the instrument panel. It has never been a problem until earlier this year, I noticed the dash cam shutting off, citing power usage issues. I replaced the cam and it is still behaving the same. I plugged in another device to this outlet and it also won't operate correctly. The USB is fine next to it is fine.
    Around the same time as the initial cam failure, my driver's door actuator starting going on the fritz and it is dead now. I can't afford to replace it yet, but was wondering if perhaps these two issues are related or just coincidental. Has anyone else experienced this?
    Thank you, I appreciate you.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,722
    6,731
    Texas Hill Country
    Sounds like there is low or no voltage on that 12v power point. Have you measured the voltage at the outlet? It has a fuse and relay controlling the power. The relay is only enabled when the car is on and the 15 amp fuse is in the interior fuse box.
    Tim Jones, Shrug and Air_Boss like this.
  3. Shrug
    Shrug Junior Member
    CA
    I have not! I will do that, thank you! A great place to start.
  4. Air_Boss
    Air_Boss Senior Member
    4,231
    1,190
    New Yawk
    If you want the cam to operate after the car is turned off, parked, wire a 12V lithium storage cell into the post-receptacle power path. Depending on cam current draw, 40,000mah should last more than 48 hours.
    Shrug likes this.
  5. Shrug
    Shrug Junior Member
    CA
    Thank you for this suggestion! I was also just thinking about running it off a power bank until the outlet issue is solved.
    Air_Boss likes this.
  6. Shrug
    Shrug Junior Member
    CA
    I acquired a voltage tester and will be using it in the next couple of days when I have the time.
  7. Tim Jones
    Tim Jones Senior Member
    1,760
    565
    SE Texas
    2011 Nissan LEAF
    and what happened?
  8. bisco
    52,566
    Never found the time…
