Power Train Removal
Discussion in 'Gen 3 Prius Technical Discussion' started by donzoh1, Oct 29, 2019.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    If the drive shafts are removed first, is it possible to remove the entire power train from the top? I've seen a YouTube video removing the engine only from the top but not the whole power train.
  2. donzoh1
    450
    153
    Lenexa, KS
    why doesn't anyone care about this question???
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    Perhaps it was just overlooked. It’s also a question that has to be answered from experience, not just from published documentation: as you may know, the removal procedure in the Repair Manual (more info) says to lower the engine assembly, with the transaxle still attached, onto an engine lifter, with the car on a lift.
    I’d also suggest asking the PriusChat moderators (use the “Report” button) to change the thread title. “Power Train Removal” could be about a hybrid-to-EV conversion or a similar flight of fancy, but “Can I lift out the engine and transaxle together?” would make it clear that yours is a practical question.
  4. donzoh1
    450
    153
    Lenexa, KS
    I don't have a lift so the only options I see are removal from the top or removing the front end parts until it comes out straight forward. Now, I'm leaning toward just the engine from the top, leaving the rest of the power train in place. With the left transaxle mount loose enough and tilting the motor up and out toward the passenger side, I'm thinking it will come out. I have another complete power train so will double check how much clearance is needed before the engine will clear the rest of the transaxle.
