Power Windows & Audio Not working after 12v battery drain
Discussion in 'Gen 3 Prius Main Forum' started by superdan54, Mar 6, 2022.
  1. superdan54
    superdan54 Junior Member
    MO
    So back in November my catalytic converter was stolen from my 2010 Prius right in my driveway in a well lit neighborhood (that's another story) :mad:
    Anyway, the car sat in the shop for 2 months while a backordered replacement could get in. By the time I got it back the 12V was completely dead. I was able to salvage it and it holds charge now just fine. However a few items no longer work. Most notably, 2 out of the 4 power windows on the master controller no longer work. The individual ones by each door work but half of the driver's controls don't. Do I just need to replace the unit or could there be something else?
    Also, most importantly my audio doesn't work at all. I have one of the JBL systems with an amplifier. I'm guessing the problem is that it just won't turn on. How can I diagnose it without just ordering a replacement to see if that's the problem. I don't want to put any more $$ than I already have :(.
  2. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    What is the voltage reading? "Holding a charge" is meaningless if the voltage is low.
  3. superdan54
    MO
    12.5V idle
    14.69V with engine running
    52,861
    everything else works and the car drives fine?
  5. superdan54
    MO
    Yes, as far as I can tell. No check engine lights or anything like that.
  6. bisco
    52,861
    sounds like something odd happened in the garage. check all the fuses to begin with
  7. superdan54
    MO
    The amp fuse looked fine. I'll check the power window one here in a few but it wouldn't make sense for half of them to work if a fuse was blown
  8. bisco
    52,861
    i know, it is very odd. maybe rats chewed on some wiring. can you take the amp out of the circuit and see what happens?
    i just can't think of a relationship between the audio and the windows
  9. superdan54
    MO
    I replaced the amp but it's still not working. I checked and I'm getting 12v power to the amp so I really have no idea what the problem could be.
  10. bisco
    52,861
    it has to be after the amp back to the dash behind the head unit?
  11. tony_2018
    tony_2018 Member
    227
    68
    do the switches work on the doors?
  12. superdan54
    MO
    Weirdly enough one of the switches started working again. However still 1 out of the 4 still doesn't work. I'm at a loss. Seems like an electrical problem that's way over my ability.
  13. bisco
    52,861
    i think you're right. something is grounding or chewed or loose
