PP 2017 battery degradation?
Discussion in 'Prime Main Forum (2017-2022)' started by Rieuk, Jan 4, 2020.
  1. Gokhan
    Gokhan Senior Member
    6,690
    2,651
    Paramount CA
    I seem be getting about 40 EV miles on a full charge in ECO city driving while observing the ECO gauge. It's a lot less for freeway driving. Does this sound about right?
    jerrymildred likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I would think so. I get around 28-30 in my '17 with mostly stop & go highway driving. That takes about 5 kWh/mile. The rare times I get to drive much on 35-45 streets, I get 5.5-6 kWh/mile, which would be around 35 miles range.
    Gokhan likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    If you are actually getting 40 EV miles out of a full tank, it is excellent. OTOH, if 40 miles is what GOM is showing you, you are likely not getting that distance. At least not in contiguous EV drive.
  4. Gokhan
    6,690
    2,651
    Paramount CA
    Yes, it's actual miles -- I don't care much about what the guessometer (what you mean by GOM?) shows. It's only in city driving with sticking to the ECO guide though.
  5. Rieuk
    Rieuk Member
    103
    Pasadena
    So I noticed my avg miles /kWh for April is 3.9. For 6.5 kWh this is just around 25 miles. 3.9 is also lower than usual but my tires are well pressurised (40psi all round). What else could I look into regarding drive efficiency?
  6. jerrymildred
    11,517
    14,164
    Tampa, FL
    Biggest thing I've found in EV driving is hard stops. They will KILL your miles/kWh. Absolutely kill it. Our idiot traffic lights often cause hard stops here because they will change at the last second on 60 mph roads and there are no warning flashers. It's either brake hard or run the light. Even at low speeds, you loose all the coasting and regen for that stop and it really lowers the numbers.
  7. bisco
    52,756
    put it in neutral at 10 mph and see if it rolls smoothly. you should actually pick up a little speed
  8. Gokhan
    6,690
    2,651
    Paramount CA
    OK, so I have checked this. I am getting 38 miles EV range, not quite 40 miles, in city driving. Of course, this is in the eco mode and following the eco gauge.
    benagi likes this.
