Pre-Charge New Optima 12v ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eful, Jan 8, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    When I said voltage alone is not a good test and then you added some other things into the mix and that changes my original statement.
    If you are doing tests in a car and you don't have a way of testing it like they do at the parts store there are some things like you said that will work with someone who has experience. We don't know what people asking questions know about electrical things. I have an electrical background but I don't claim to know everything about a Prius especially the Lithium Ion battery system, but I do know 12V car batteries.
    Taking the battery to be checked at the parts store with proper equipment to say the battery is in good health is a way to confirm a batteries health. By doing this you totally eliminate one piece of the puzzle, then you move on.
    Most of the people here haven't a clue about a basic 12 V battery and need to be spoon fed information. It's just a new subject to them and they can learn if they want to put forth the effort. Most of them are learning under fire and I feel sorry for them because they mostly only have one car and it is broke down.
  2. padroo
    2,763
    2,253
    I have the Solar BA5 tester, very nice piece of equipment to have as I have many batteries, at least 11.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    No it isn't.
    CCA "rating" is pretty meaningless but the test is: Note the resting voltage. Be sure it is within a fairly narrow acceptable range. Apply a LARGE LOAD and see how much the voltage drops. That is a perfectly valid test for any battery.
    NOW......doing that just once and having it "pass" does not guarantee that it really is a "good" battery, regardless of what application it will be used in.
  4. Sam Spade
    2,036
    1,024
    2017 Prius c
    No it doesn't. Those tests are good but not thorough enough.
    A really LOT of people have found out that a battery that passes their one shot test and is pronounced "good" really isn't.
  5. Sam Spade
    2,036
    1,024
    2017 Prius c
    Voltage alone IS a good test........IF you really know what you are doing. (y)
  6. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Because CCA does not literally apply, perhaps it should be a CBUA (cold boot-up amperes) test.on a Prius.
    Some brands of batteries sold for Prii are really repurposed starting batteries, which is why they have CCA specs.
  7. txtabby
    txtabby 2011 Prius 4
    139
    Austin, TX
    I don't know if this really applies to this thread, but I've gone through several OPTIMA Yellow Top batteries in the past 4 yrs. Yes, mostly my fault, but since I got my Tesla, the Prius is my back-up car (Home Depot, etc). And I figured driving it 20 min every 2 weeks would be enough. Well I kind of back-slid/forgot and batteries died. Recharged one with a non-auto charger & almost blew it up overnight. Now I know what to do, but I still didn't drive enough, dead batt. Had an extra one that was charged up, for 6 mos that read 11.5V, it worked. Put the dead one (less than 6V) on a charger, v e r y s l o w l y losing charge, was at 13.7v, now at 12.92 over 2 days. Been driving the car every day for at least 30 min. QUESTION: How do I keep from going through batteries? Do I need a new one from Toyota-they have a great warranty if they install it, or get another OPTIMA ($$$) and just SCHEDULE to drive it Every Week? Or, just see how these 2 batteries hold out? Ok, I think that's it... lol
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Ah, another for the archives.
