Pre-collision system malfunction
Discussion in 'Gen 4 Prius Main Forum' started by shadow4478, Nov 16, 2022.
  1. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    134,000 km
    Today out of nowhere message displayed “pre-collision system malfunction visit your dealer”
    Cruise controller raider works Lene assist works any information on this?
  2. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    The windshield was changed about two months ago. They did say it may need to be recalibrated, not sure if that has to do with anything as the lane sway assist works
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Shadow,
    The radar is behind the Toyota front emblem. If it gets dirty, the safety systems can shut down. Take a wet rag and clean it. Hopefully that will correct the issue.
    JeffD
  4. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    No, it’s clean washed off same thing
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    To find out why the message appeared, you (or a dealer or independent shop) need to retrieve the diagnostic trouble codes (DTCs) stored in the driving support ECU assembly, and then review the related information in the Repair Manual (more info).
    This requires a Toyota Techstream diagnostic system or true equivalent; inexpensive OBD II code readers made for engine and emissions diagnosis aren’t programmed to communicate with the driving support ECU.
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    A camera recalibration is definitely required after windshield replacement. Otherwise, have you disconnected your 12V battery lately? There is an ECU requiring a reinitialization procedure. The non-operational fault is mentioned in the user manual on page 301, and the initialization procedure is on page 383. These procedures may be on different pages in your manual. My manual is Toyota 2021 Prius Owner's Manual (OM47E09U).
  7. MikeV
    MikeV Junior Member
    95
    philadelphia
    Did you ever figure this out?
    Having exact problem as yours
  8. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    For me it was the camera, they nicked a clip while replacing the windshield, they tried to tape it with double sided tap but didn’t work, then they ordered a new clip and it worked without issues.
  9. MikeV
    MikeV Junior Member
    95
    philadelphia
    was it covered under warrant and why did the lda LDA still work
