Pre-Collision System Radar assembly cost?
Discussion in 'Gen 4 Prius Main Forum' started by HerbMPG, Dec 5, 2024.
  1. HerbMPG
    HerbMPG Junior Member
    30
    Decatur GA
    Well, my 16-year-old daughter mistook the gas pedal for the brake and slammed into a brick wall in our 2016. At first, everything seemed OK, but a few days later the pre-collision system unavailable message came up. I also believe the automatic cruise control will not work. If I’m not mistaken, the problem is with the sensor behind the Toyota emblem at the front. I assume replacement cost will be $600-1200. Is this something I could possibly change myself, even if I need to get someone else to recalibrate it? Is buying a used one a bad idea? Is it that sensitive that it should fail after being hit?
  2. jdenenberg
    jdenenberg EE Professor
    3,914
    1,914
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That sensor is actually a radar unit and you will find it to be quite expensive.
    JeffD
  3. BiomedO1
    BiomedO1 Senior Member
    2,669
    1,429
    SacTown, Ca
    I'd search for one @ the wrecker/junkyard, side or rear impact car. IMHO
    Yes, cruise control won't work - car can't judge distance from car in front until this is repaired. Did you check for loose wires and connectors?
  4. Mendel Leisk
    40,369
    What's your insurance like?
  5. Falcon6v
    Falcon6v New Member
    Tampa
    Four Touring
    Toyota uses the same sensor for the corrola. Look up the part number then do an ebay search. They are super easy to replace and i have seen them for as low as $200.
