Predictive efficient drive
Discussion in 'Prime Fuel Economy & EV Range' started by civicdriver06, Mar 20, 2017.
  1. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    How does the "Predictive Efficient Drive"mentioned in the Prime'brochure work ?
  2. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    When you are viewing the EV MONITOR screen on the multi-information display, you would see a BLUE bar that changes dynamically. That bar is from PED, showing you how much power you should expect to use on the road that you often drive on based on your driving history. It helps guide you in terms of how efficient you can be.
    If you turn on the PED display on the NAV settings for the 11.6in screen, you will see a lot of green leaves or trees on the map. That is based on your driving history of all the places you have often driven to and needed to slow down or stopped.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    so far I haven't seen the green leaves on my display. I have tried and failed to turn on the PED display, so could you, Optimus PRIME guide me there?
  4. civicdriver06
    797
    324
    Germany
    Ok thank you .
    I can't remember Toyota mentioning that feature for the European version .
    They did rmention that power-mode adapts to the drivers driving habits.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
  6. Crowmag Naman
    Crowmag Naman Junior Member
    29
    albany new york
    Prime drivers will eventually notice the car slowing down noticeably more by itself at stop signs or intersections they commonly travel.
    The navigation remembers the location where the car always decelerates or stops. Then uses the registered points to increase the engine breaking sending more juice back to the battery - Predictive Efficient Drive - Pretty Cool!
    Apple Prime likes this.
  7. Tideland Prius
    16,680
    It may or may not be available in Europe. In the North American Prime owner's manual, it appears Canada will not be getting PED.
  8. Crowmag Naman
    29
    albany new york
    the navigation manual says it only available in the the US. no Alaska or hawaii
