Preferences for map direction
Discussion in 'Prime Audio, Electronics, and Infotainment' started by MNdriver, Jun 5, 2017.
  1. North is up (like a map)
    29.6%
  2. The direction you're traveling in is up
    70.4%
  1. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    GASP!!!!!
    Oh... and see my comment #20 "above". The image you shared shows JUST the type of situation I alluded to!
  2. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Same here, it's just ingrained in me for too long.
    Pdog808 and Prius from Dad like this.
  3. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    North is up. Always. I tried heading up but then I lose what direction is north, and when the road is curvy the constant flipping around is distracting. When navigating and following directions, there is a benefit to a 3D heading view, though - it does make the right and left turns a tiny bit easier.
    In either case, I would also like the car's position to be toward the edge of the map to increase the view of the area you're approaching. I don't care what's behind me, I've already gone past it.
  4. DavidA
    2,349
    1,825
    Chicago western burbs
    Oooohhhh! This is good to know. Thanks!
    I am also overjoyed that the car is still represented as the flying candy corn spaceship.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    My sentiments exactly.
  6. Son of Gloin
    421
    320
    Lafayette, IN
    "... flying candy corn spaceship...."
    HAH!!! :ROFLMAO: :D :ROFLMAO:
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    This. Exactly.
    benagi likes this.
  8. Tideland Prius
    16,674
    Direction Up for me.
    It can get annoying on a curvy road (cause the map is always rotating) but on city streets, I can always look at the same part of the screen (the top part) to see what streets are coming up. If I use North Up, then I have to look at different parts of the screen depending on the direction I'm travelling to see the name(s) of the upcoming streets. When you're glancing at the screen, that milliseconds that are required to scan the screen in North Up isn't worth it as you would've travelled several feet in those milliseconds.
    Besides, there's a compass built into the nav (that same button you press to cycle through the different map modes) so I can always look at that to find the direction.
    alexcue likes this.
  9. BarbM
    BarbM New Member
    Columbus, Oh
    So how do I change it so it shows the direction I'm going?
    Thanks
  10. Lee Jay
    5,850
    4,036
    Page 206 of the navigation manual.
    BarbM and Mark57 like this.
  11. Mark57
    2,945
    2,740
    OK
    Also, if you ever scroll the map or get it off center to where you actually are, just press the Home button to the right. It will re center the map.
  12. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    So is there South UP option for Aussie?:LOL: Personally, I have Garmin on the dashboard and I have not used Toyota Nav ever since I purchased my PRIME.
    Mark57 and HPrimeAdvanced like this.
  13. BarbM
    BarbM New Member
    Columbus, Oh
  14. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    The ability to switch between north-up and direction-of-travel up has been there since at least the Gen 2 nav. I've had nav in Gen 2, 3 and now my prime. I've always found it easier to use direction up rather than have to do the additional special translation to try to figure out if an up-coming turn is left or right (although the HUD does help with that a lot. I find I hardly look at the map at this point (usually just to see eta).
  15. pyramidbuilder
    pyramidbuilder New Member
    Novato, CA
    My preference has always been for top of map the same as direction of travel. That means the map top shows me what's ahead.
    Lightning Racer likes this.
  16. pyramidbuilder
    Novato, CA
    I would not mind the satellite view on the Prime. I know it's available on the Tesla (well, the Prime costs $80K less than the Tesla)
  17. SteveMucc
    391
    268
    Kentucky
    For me, the map is busy enough. I can get just the information I want in a quick glance. Having the satellite view would just make it that much harder to read quickly and get what you want (which is directions).
    I would honestly only use it when I was parked and then when i'm trying to find a destination that's difficult to view. if it had a street-view option that would be even better, but again, only when parked.
    pyramidbuilder likes this.
  18. Tideland Prius
    16,674
    Satellite view (Google Earth) is also available on select Audi products.
    Street View is available on European Toyota products (to view the surroundings of your destination).
  19. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    North up for planning and if using paper maps. Direction up for traveling with scrolling displays.
  20. jon1111
    jon1111 New Member
    thousand oaks, ca
    I use North up when I am in a new area that I want to get situational awareness. But if I am local or don't care, its easier to have the direction you are driving. So I do switch.
    benagi likes this.
