Premium and Advanced - where are you mounting your cell phone?
Discussion in 'Prime Main Forum (2017-2022)' started by ruby, Jan 23, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    [QUOTE="Can't use aux with the new iPhone. [/QUOTE]
    If you're referring to the fact that it doesn't have a headphone jack, it comes with an adator to the "lighting" jack. I use it fine on my 2009.
  2. ruby
    ruby Member
    130
    78
    If you're referring to the fact that it doesn't have a headphone jack, it comes with an adator to the "lighting" jack. I use it fine on my 2009.[/QUOTE]
    True. I used it that way in my older Prius, too. I probably should not have used the word "Can't" there.
    I don't use an aux adapter with an iPhone 7/7+ in the Prime since the Prime supports audio with a Lightning cable in the USB port. That is my preferred method of connecting the phone for music.
  3. geguia
    geguia Active Member
    210
    108
    los angeles
  4. geguia
    210
    108
    los angeles
    and a permanent circle on your dash. i had one on my previous car.
  5. geguia
    210
    108
    los angeles
    does
    doesn't your phone flop left to right with the vent? might need to stick something in there
    no great solution IMO
    DO NOT GET THOSE STICK MOUNTS unless you want an ugly ring for the life of the car
  6. mr88cet
    2,313
    1,335
    Austin, TX
    Roger! When you do that, does it also charge the phone over that USB connection?
    Granted, for me at least, that's not generally a big concern, since iPhone 7 battery life is usually not an issue for me. Still, certainly would be nice at least if so!
    iPhone ? Pro
  7. ruby
    ruby Member
    130
    78
    It charges it as well, yes. Note that due to problems some folks reported on these forums, I put my newest straight-from-Apple USB / lightning cable in the new car, rather than an older / third party one. So far no problems cable wise (although I've been seeing a few random bluetooth issues not unlike what others have reported).
    mr88cet likes this.
  8. mr88cet
    2,313
    1,335
    Austin, TX
    Good to hear (that it charges too).
    I gather that the Anker Powerline+ cables seem to help with the connection flakiness.
    iPhone ? Pro
  9. mr88cet
    2,313
    1,335
    Austin, TX
    Does the USB connection also function as a data connection for Toyota's Pandora (etc.) Entune apps? That, as opposed to piping the Internet connection via Bluetooth?
    iPhone ? Pro
  10. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Yes, but you can't have both enabled at the same time. If you have it plugged in, you have to disable bluetooth.
    mr88cet likes this.
  11. Swauger
    Swauger Member
    37
    35
    PA
    Sorry, but what's the name of the car holder that you use? I'm looking through the thread and can't find it. Obviously, I'm missing something.
  12. Lee Jay
    5,850
    4,036
    That's really odd.
  13. Bobdski
    Bobdski Junior Member
    37
    Rockaway, NJ
    I do the same a magnetic on the vent
  14. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I just lay my Samsung S7 on the QI charging pad where the phone charges and it connects beautifully with Bluetooth. The only difficulty is that occasionally when you corner hard, your phone may slide around a little bit and the connection might be less effective in charging the phone.
    Silent Propulsion likes this.
  15. FA6
    FA6 Member
    45
    150
    Pardon my ignorance but why cannot you charge your iphone on the tray?
    HPrimeAdvanced likes this.
  16. Prodigyplace
    12,560
    11,778
    Central Virginia
    The iPhone does not support Qi charging, but they could plug a charger into the accessory outlet & still use the tray, I believe.
    #36 Prodigyplace, Mar 22, 2017
    HPrimeAdvanced, FA6 and mr88cet like this.
  17. mr88cet
    2,313
    1,335
    Austin, TX
    Current iPhones, that is. Rumor has it that the iPhone 8 will support Qi charging.
    FWIW though, in my particular case, charging nightly, I rarely drop down below ~40% on a day's usage on my iPhone 7+, and similarly for iPhone 5S and 6+ before it. Occasionally, but not often; almost never to where it complains about being low. Again, just FWIW...
    iPhone ? Pro
    FA6 likes this.
  18. FA6
    FA6 Member
    45
    150
    Thanks mr88 and Prodigy
  19. CharlesH
    2,797
    1,163
    Roseville, CA
    You can get a Qi case for the iPhone, can't you? Don't know personally; I am an Android person, and all the recent phones I got have Qi built it.
  20. mr88cet
    2,313
    1,335
    Austin, TX
    So I hear.
    iPhone ? Pro
