premium custom LED interior kit??
Discussion in 'Gen 3 Prius Accessories and Modifications' started by priusG, Nov 22, 2011.
  1. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    EvilBay is my nickname for eBay
  2. priusG
    priusG Junior Member
    30
    Los Angeles
  3. priusG
    30
    Los Angeles
  4. sofistikats
    sofistikats New Member
    Burlingame, CA
    Has anyone used this? I tried emailing iJDMtoy but havent received a reply yet.
  5. priusG
    30
    Los Angeles
    FYI, information of the exLEDusa interior kit in this forum
    exLEDusa 10pc LED set | PriusChat
  6. k.s.c
    k.s.c Junior Member
    73
    SW Florida
    you wont get a reply from iJDM. they have the worst customer service out there. plus their light sets dont fit the new 2012 prius. I know. I bought one. they said "oh well"
  7. Steve Type-4
    Steve Type-4 Trading HP for MPG
    174
    102
    SoCal
  8. corystal
    corystal Junior Member
    40
    Los Angeles
    How does the dome light dimming on/off work with these? I would assume that it doesn't, and that they just pop on.
  9. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    they work coincide with the front map lights. make sure switch is in proper position.
  10. Fore
    Fore Don't look back!
    494
    107
    One problem with these cheap LED lights is they don't last especially on the exterior of the car, parking lights in the front flicker as well as the license plate after six months of use so I replaced them with the originals. Interior ones still seem to be working ok.
  11. corystal
    40
    Los Angeles
    I meant do they fade on and off the way that the incandescents do? Like when you walk up to the car and they fade on, and when they fade off after you get in and close the door. Usually LEDs aren't dimmable.
  12. munkeeboi
    munkeeboi Active Member
    100
    173
    Try bending the wires out at the base if they flicker. They might not be getting good contact. I though I had bad led's too, but after doing this, the lights are fine now and don't flicker
