Pressed pedal, engine revs but no power to the wheels...
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by zor, Dec 6, 2016.
  1. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Never use B mode short of an emergency. Braking mode is there for regulatory compliance. You're not driving a truck. Your brakes will last the life of the car (unless you live in Buffalo NY then they'll rust out).
    zor and krmcg like this.
  2. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    B Mode is convenient when you are descending a long grade and don't want to sit on the brake pedal. We have several roads near me (Oakland, CA) where it is a convenient option to have.
  3. Mendel Leisk
    41,489
    I would reserve B for extremely long downgrades, only use it where the car may refuse to charge further, dump the braking task 100% onto the friction brakes, well before the bottom. That would be at least a mile of sustained downgrade.
    RCO and krmcg like this.
  4. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    B mode is great for stop and go driving, provides a bit more drag so you don't have to hit the brakes as hard or as often. Also, IF you have a Plug-In model, going downhill, when the battery bars fill up, it will just switch the battery gauge to solid and charge as if you were plugged in. The most I've ever got on a hill was 1.0 miles of charge :D
    iPhone ?
  5. Mendel Leisk
    41,489
    On a regular Prius, it'll also ensure less charging. Seriously, relegate B mode to mountain descents.
    Prodigyplace, RCO and krmcg like this.
